Difference between M21 and M22
Old Dec 19, 2003 | 07:50 PM
S.J.S.'s Avatar
How can you tell the difference????
Old Dec 19, 2003 | 09:07 PM
angel71rs's Avatar
Only way to be sure is to look at the gearset. This site compares the M22 gears to M20 gears (same as M21 except for ratio):
http://www.gearzone.net/muncie3.htm
Old Dec 20, 2003 | 08:09 AM
Tim H's Avatar
I think on the imput shaft there is single ring around it for a M21,double for a M20 and no ring for a M22.
Old Dec 22, 2003 | 04:23 AM
91 GTA Ramair2's Avatar
only real mjor differnce is the M-22 is heavyer built then the m-21
The M-22 in the Rock Crusher after all.
Old Dec 22, 2003 | 07:18 PM
MSM69Z28's Avatar
m22 is a straighter cut gear than the M20 and 21. straighter gear cuts can tolerate more power. jerico and other big name trasn builders often use straight cuts gears and m22 i think is cut at a 45. m20 and 21 are more, but i don't remember how much.
Old Dec 22, 2003 | 11:11 PM
So the m-20 M-21 or the M-22 Rock Crusher???
Old Dec 23, 2003 | 12:50 AM
bgreenard's Avatar
The M22 is the "Rock Crusher" because of the whine of the straighter cut gears. It is stronger than the M20 wide ratio and M21, but it is not indestructable. I know! I have destroyed them all. The Super T10 is just as strong IMHO as the M22 even though I have broken that one too
Old Dec 23, 2003 | 01:18 AM
Well Cool stuff the AMX has the Crusher....
WobblySausage
Oct 7, 2015 02:44 PM
NewsBot
Sep 30, 2015 04:20 PM
SergheiS
Sep 29, 2015 08:56 PM
Bxlt1
Sep 29, 2015 03:18 PM
