700r4 conversion q's
Old Dec 19, 2003 | 04:12 PM
Asr_off's Avatar
ok , i have a 96 camaro , just got my 4l60 outa a 93 trans am . I have the tv cable allready figured out , prettymuch ready to go , but only one thing is stoppin me , anyone know how i have to wire up the trans for the converter to lock up . all the info ive found is for a 4 prong connector and the connector i have is a 6 prong , any help will be appriciated! thx
Old Dec 19, 2003 | 08:00 PM
Sneakin Deacon's Avatar
im not sure that works, 93's arent electronically controlled like the rest of the 4th gens.
Old Dec 20, 2003 | 02:39 AM
Asr_off's Avatar
correction , 5 prong not 6
Old Dec 22, 2003 | 03:38 PM
Pro Built Automatics's Avatar
The 5 prong is a 1993 TA only. You will need a wiring schematic for this to determine on what to do for the lockup. You can use the GM vacuum switch setup for this, if you have disabled the computer that controls lockup.
Old Dec 23, 2003 | 03:24 AM
Asr_off's Avatar
yea your correct , i did the research for it , and just incase anyone was wondering on the 5 prong connector , the terminal closet to the ft of the bellhousing needs a 12 volt source conneted to the cruise control switch "as an intrupptor to unlock the converter while breaking" to lock up in 4th gear , ill make a diagram and post it on here so people will have refrence
Old Dec 23, 2003 | 04:37 AM
dkeers's Avatar
I am using a kit (made by TCI ~$75-$100) to control lockup on my 700r4 in my '95. It uses 3 switches wired in series. One is on if the tranny is in 4th. One is on if the brakes are not pressed. One is a vacuum switch that is on if there is vacuum present. If all of these criteria are met then the converter locks up. I actually left out the vacuum switch because no one could give me a good reason to use it.
Does anyone know why I should add it?
Dustin
Old Dec 23, 2003 | 03:41 PM
The vacuum switch tells it to unlock the torque converter at low vacuum, and at high vacuum. It's when it is in between that it stays locked up.
Mar 13, 2016 03:37 PM
Jake Bialke
Sep 24, 2015 11:31 AM
92_RS_305
Sep 8, 2015 07:47 PM
tdigger9899
Sep 7, 2015 10:56 AM
Cam's maro
Aug 11, 2015 07:45 AM
