Torqing Pinion Nut
Old Dec 18, 2003 | 01:05 AM
Heatmaker's Avatar
Advanced Member
Torqing Pinion Nut
On a set of Motive 4:10's......with the basic GM crush Sleeve.... (non Ratech) what should the Proper Pinion torque be? THe manual says 96FT Lbs...is that ok to use on a set of 4:10's?
Old Dec 18, 2003 | 09:35 PM
97WRAITH's Avatar
Buddy this is the third post I have seen on this subject. No wonder you have so many posts in just 1 month of beening on this board.
Old Dec 18, 2003 | 10:37 PM
Heatmaker's Avatar
Advanced Member
lol's no really i like to post the differential questions here and in the lt1- tech threads...only because different people hang out on different threads and you can get more info that way. sometimes if i ask a question here no one may read it...but if i post the question in the tech thread it'll have like 8 replies...didn't really pay much attention to my 600 post till you mentionrf it though lol's.
Old Dec 19, 2003 | 09:10 AM
carnutz's Avatar
You tighten it untill you get 20 to 25 IN LBS of preload on the pinion bearings!!(new bearings of corse) There is no torque spec for the pinion nut.........
Its tight as hell if you never have done it.
Old Dec 19, 2003 | 09:45 AM
thermwood1's Avatar
The torque spec on the pinion nut for my set of Precision Gears 3.73 was 125 ft. lbs. Don't know if it's the same for the Motive Gears. Oh yeah, i also used a solid pinion spacer.
Old Dec 19, 2003 | 07:56 PM
ROCKN SS's Avatar
Like he said.
Old Dec 19, 2003 | 09:30 PM
jcornss's Avatar
Yes, you need to measure pinion bearing preload not pinion nut torque.
Victor Lamb
Aug 26, 2017 02:52 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
tdigger9899
Sep 7, 2015 10:56 AM
Dams76
Aug 20, 2015 08:28 AM
kev93z28
Aug 19, 2002 12:48 AM
