18 mpg
Old Dec 14, 2003 | 08:35 PM
Klypto's Avatar
18 mpg
how the hell ppl hit mid 20s in the city??? i hit mid 20s on highway, just did 18 with babying the entire time(6spd)
wierd, 18 still good in my book for what it is....
cory
Old Dec 14, 2003 | 08:39 PM
95GRNZ's Avatar
Question
How many miles on your car?
Old Dec 14, 2003 | 08:44 PM
Klypto's Avatar
just hit 62600 runs perfect... may need some help to.. "make it run better" but still runs great
Gloveperson's Avatar
Maybe they have some gears at the rear and can shift into 5th while doing 30? IDK if that is the difference, but I would also like to know how y'll guys get 20 in the city, too. My LT1 would get 15 on good tanks.
Old Dec 14, 2003 | 08:47 PM
Klypto's Avatar
ps - the entire tank, never went over 1800 rpm... normally 1500-1800
1st - 10 mph
2nd - 20 mph
3rd - 25 - 30 mph
4th - 30 mph
5th - 35 - 40 mph
6th - 48 - 55 mph
(all these numbers are averages i guess, cant be exact...)
is driving in 6th gear around 1100 rpm worste than driving in 5th at around 1600??? i was thinking maybe more stress on engine that low... dunno...
Old Dec 14, 2003 | 11:29 PM
Ferocity02's Avatar
Keep in mind if you shift too early, you will find yourself giving it more gas to accelerate using more fuel, even if you don't think you are. Anyways, 18 mpg in the city is damn good in my opinion. Mine gets 21-22mpg with 50% highway and 50% city.
Old Dec 14, 2003 | 11:54 PM
Beast96Z's Avatar
I average around 18 mpg. Like the other said, keeping your rpms to low will cause you to use more gas upon accelaration. I like to keep my revs around 1500-2000 for cruising.
Old Dec 15, 2003 | 01:36 AM
mr_muff's Avatar
same here. i find that you still have enough go when you give it a litle bit of gas to get infront of ppl without having to drop a gear, and the gas mileage is pretty good.
Old Dec 15, 2003 | 07:36 AM
teke184's Avatar
have you thought of changing your o2 sensors? they could be bad or gummed up.
doesn't that affect milage?
how bout tire pressure?
Old Dec 15, 2003 | 01:50 PM
rncotton's Avatar
I used to get 18 MPG in the city on my stock 3.42 rear. Now, with the 4.11 rear, I get 17 MPG.
58K miles, oil slipping past the piston rings, but I'm not paying the grease monkeys to install the new ring kit. I'll just continue buying oil in the 5 quart jugs.
Aug 24, 2015 06:41 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
grgguy
17
Feb 23, 2015 07:57 PM
Meccadeth
Dec 14, 2002 08:37 PM
Willy boy
Jun 8, 2002 02:37 PM
