Cadillac STS info
Old Nov 26, 2003 | 10:49 AM
formula79's Avatar
Cadillac STS info
Again from GMI...
Option Code Description
A45 Memory Package
AL2 Seat adjuster, power
AP3 Keyless Access, includes keyless ignition which is engaged with push button start
AP9 Convenience Package, includes universal transmitter garage door opener
AQ9 Seats, front bucket
AY0 Air bags, frontal dual stage and side thorax for driver and front passenger
B19 Wood Trim Package
B20 Wood Trim Package, includes real eucalyptus wood on steering wheel
CE1 Wipers, Rainsense
CE4 Headlamp washer system
CF5 Sunroof, power
DD7 Mirror, inside rearview, electrochromic
DD8 Mirror, inside rearview, electrochromic
DR2 Mirrors, outside rearview
DT4 Smoker's Package
FE1 Suspension, 4-wheel independent
FE3 Suspension, 4-wheel independent with Magnetic Ride Control
FE9 Emissions, Federal requirements
JE5 Brakes, 17"
JL4 StabiliTrak
JL9 Brakes, 16"
K05 Engine block heater
K14 Air filtration system, outside recirculating air filter
K59 Cruise control, adaptive
KA1 Seats, heated
KA6 Seats, heated
KB6 Seats, heated/ventilated
LH2 Engine, 4.6L Northstar V8 VVT
LY7 Engine, 3.6L V6 VVT
M22 Transmission, 5-speed automatic
M82 Transmission, 5-speed automatic
MV3 Transmission, 5-speed automatic
N31 Steering wheel, heated
N87 Wheels, 4 - 18" x 8" (45.6 cm x 20.3 cm) cast aluminum polished
N88 Wheels, 4 17" x 7.5" (43.2 cm x 19.1 cm) cast aluminum painted
N93 Wheels, 4 - 17" x 7.5" (43.2 cm x 19.1 cm) aluminum polished
NC1 Emissions, California LEV
NE1 Emissions, Geographic Restriction for up to 14,000 lbs. GVW
NG1 Emissions, Geographic Restriction for up to 6000 lbs. GVW
NP5 Steering wheel, leather-wrapped rim
NR7 Steering wheel, leather-wrapped rim
NT7 Emissions, Federal
NT9 Emissions, Federal
NU1 Emissions, California
NV7 Premium Steering Gear, ZF
Q11 Tires, P235/50R17 front and P255/45R17 rear
Q12 Tires, P235/50R18 front and P255/45R18 rear
Q13 Wheels, 2 - 17" x 7.5" (43.2 cm x 19.1 cm) front, 2 - 17" x 8" (43.2 cm x 20.3 cm) rear
Q14 Wheels, 2 - 17" x 7.5" (43.2 cm x 19.1 cm) front, 2 - 17" x 8" (43.2 cm x 20.3 cm) rear
QKP Tires, P235/50R17
T43 Spoiler, decklid
TQ5 Headlamps, Intellibeam
TT6 Headlamps, Xenon, high-intensity discharge
U2K Sound system feature, XM Satellite Radio
U30 Instrumentation, analog
UA6 Theft-deterrent system, PASS-Key III
UD7 Rear Parking Assist, Ultrasonic
UE1 OnStar
UG1 Universal transmitter, HomeLink
UJ6 Tire pressure monitor system, air pressure sensors in each tire
UV6 Head-Up Display
V03 Performance Cooling Package, includes P/S cooler
V08 Cooling system
YF5 Emissions, California state requirements
YQ1 Sound System, ETR AM/FM Bose 4.0 with CD player
YQ2 Sound System, ETR AM/FM Bose 4.0 with in-dash 6 disc CD changer
YQ3 Sound System, ETR AM/FM Studio Surround Sound Bose 5.1 with in-dash 6 disc DVD changer
YQ4 Sound System, ETR AM/FM Studio Surround Sound Bose 5.1 with in-dash 6 disc DVD changer
Keyless Access, includes keyless ignition which is engaged with push button start, and 2 remote transmitters which enable passive entry on both front doors and trunk, and remote start capability
Lighting, illuminated entry and exit, includes courtesy lamps and entrance lamps in base of door and under IP
Tail lamps, LED illumination
Wheels, 4 17" x 7.5" (43.2 cm x 19.1 cm) cast aluminum painted, 7-spoke
1 - Upgradeable to (N93) Wheels, 4 - 17" x 7.5" (43.2 cm x 19.1 cm) aluminum polished.
Driver Shift Control
Engine, 3.6L V6 VVT (260 HP [193.9 kW] @ 6500 rpm, 252 lb.-ft. [340.2 N-m] @ 2800 rpm)
1 - Requires (M82) Transmission, auto, 5-speed, HMD, 5L40-E
Engine, 4.6L Northstar V8 VVT, SFI variable valve timing, Northstar (320 HP [238.6 kW] @ 6400 rpm, 315 lb.-ft. [425.3 N-m] @ 4400 rpm)
1 - Requires (M22) Transmission, auto 5-speed, HMD, 5L50-E for RWD or (MV3) Transmission, auto, 5-speed, HMD, 5L50-E PTU for AWD
Sound System, ETR AM/FM Studio Surround Sound Bose 5.1 with in-dash 6 disc DVD changer, DVD-based Advanced Navigation, includes Radio Data System, seek-and-scan, digital clock, automatic volume compensation, TheftLock, weather band, digital signal processing and 15 speakers, rear passenger A/V jacks
Steering wheel, leather-wrapped rim, heated
Headlamps, Xenon, high-intensity discharge, windshield wiper activated, includes flash-to-pass and headlamp washers
Spoiler, decklid
Wheels, 4 - 18" x 8" (45.6 cm x 20.3 cm) cast aluminum polished, 9-spoke faceted
Brakes, 17", performance
(i'm not listing ALL options, just the most upscale)
Head-Up Display, reconfigurable, includes digital readouts for vehicle speed, selected gear, adaptive cruise indicator, radio information, high-beam indicator, fuel level, six languages available (English, French, German, Italian, Japanese, Spanish)
1 - Included and only available with (K59) Cruise Control, adaptive
Instrumentation, analog, includes speedometer, tachometer, fuel gauge and engine water temperature gauge
Limited Slip Differential
Performance Cooling Package, includes P/S cooler, mechanical engine driven fan and 2-80 watt pusher electric fans
COLORS
Blue Chip
Red Line
Black Raven
Silver Smoke
Sand Storm
Moonstone
Light Platinum
Silver Green Metallic
White Lightning
Interior
Light Gray
Ebony
Light Cashmere
Wheelbase 116.40 (2957)
Overall length 196.30 (4986)
Body width 72.60 (1844)
Overall height 57.60 (1463)
Front track width 61.80 (1570)
Rear track width 62.30 (1582)
Head room, front 38.70 (983)
Head room, rear 37.90 (963)
Shoulder room, front 58.60 (1488)
Shoulder room, rear 57.40 (1458)
Hip room, front 54.60 (1387)
Hip room, rear 55.60 (1412)
Leg room, front 42.60 (1082)
Leg room, rear 38.30 (973)
Fuel capacity, approximate, gallon (liters) 17 (64)
Seating capacity (front/rear) 2/3
Automatic Transmission Ratings with Ball Hitch
Maximum Trailer Weight lbs. (kg) Maximum Trailer Weight lbs. (kg)
STS 3.6L V6 VVT 1000 (454)
STS 4.6L V8 VVT 1000 (454)
Old Nov 26, 2003 | 11:45 AM
Meccadeth's Avatar
What a great news day Too bad no big HP engine yet though.... :blah:
Old Nov 26, 2003 | 12:25 PM
Z28x's Avatar
320HP is pretty good, it is as much as a LS1 Camaro
but if it is BIG HP you are looking for I guess you will have to wait for the V-series.
I think the tire sizes are wrong. With those sizes the front tires will be taller than the back
Old Nov 26, 2003 | 04:35 PM
guionM's Avatar
I guess no one noticed the wheelbase vs the overall length, huh?
You guys need to look beyond just horsepower numbers.
Other things overlooked:
* It has pushbutton keyless ignition .
* It has 17" front brakes! Misprint perhaps?
* It's steering wheel is heated.
* It has bigger tires in the rear, than it does up front (235s vs 255s)
* It has tire pressure sensors
* The performance has a Power steering cooler!
* The engine fan is mechanically driven, not electrically driven.
* It's almost 58" tall!
* and finally, it's fuel tank is only 17 gallons. Same as the CTS, but less than the GTO (18.5), the Lincoln LS (18), and the current Cadillac Seville (18.5 gallons). All which get better fuel economy than is expected for the new STS.
Old Nov 26, 2003 | 05:01 PM
AdioSS's Avatar
West South Central Moderator
My guesses and thoughts:
* I think the 16" and 17" notes are for the sizes of the wheels that the different brakes go on.
* The rear 255/45 tires are .3" shorter than the front 235/50
* Mechanical fan? Sheesh! At least there's another 10hp gain by switching to electrics
* I think (hope) the height is a typo
* And I hope the fuel tank is over 20gallons. With that height and weight, it will need a bigger tank
Old Nov 26, 2003 | 05:08 PM
Z284ever's Avatar
Definately a misprint.
Old Nov 26, 2003 | 07:46 PM
Z28x's Avatar
The back are wider than the front, the front are taller than the back, not by much though. I can't see why GM would do this, I bet it will change. I don't think the gas tank is a big deal, 1.5 gallon less than the car it replaces isn't that much.
It sounds like it is going to be a great car Can't wait to see it, definatly has some wourld class features. Glad 17" rims will be standard, 18" an option, it's about time GM gets away from 16" on expensive cars. AWD option is cool too.
Old Nov 26, 2003 | 10:00 PM
DarthIROC's Avatar
SO it has options for RWD, or AWD?
Old Nov 27, 2003 | 05:25 AM
morb|d's Avatar
they should definitely do something on the Northstar for Caddys. its a pretty good engine as it is and its quite big. but VW/Audi gets 340hp - 360hp from their 4.2L V8 @ 7000rpm. the larger 4.6l Northstar should have no trouble matching this at a lower rpm. GM should tune the Northstar more aggresively if Caddy is truely aiming for "world class".
Old Nov 27, 2003 | 11:35 AM
Z28x's Avatar
I think in the XLR you are right, but in the other cars it should stay how it is. More aggresive = worse gas milage.
DarthIROC - it looks like RWD is standard, AWD optional.
Old Nov 27, 2003 | 04:11 PM
coldasice's Avatar
The Audi 4.2 DOHC has 40 valves...
Old Nov 27, 2003 | 04:38 PM
morb|d's Avatar
the 4.6L Northstar has more displacement...
blac94Z
Nov 4, 2015 01:59 PM
colts0455
Oct 4, 2015 09:47 PM
drt
Sep 27, 2015 04:39 PM
frankrizz
Sep 23, 2015 04:21 PM
CARiD
Sep 7, 2015 08:21 AM
