what is this tube for?
Old Nov 20, 2003 | 09:51 PM
jibbie's Avatar
what is that tubing for that plugs into the air box on the right side? not the air temp sensor. it looks like it draws in air from the stock box, so i hooked it up in a similar fashion with my new ram-air box. is it needed? will bypassing it improve/degrade performance? thanks alot guys.
Old Nov 20, 2003 | 10:10 PM
Ron78Z&01SS's Avatar
It's the inlet line for your A.I.R ("smog") pump. Leave it connected.
Old Nov 20, 2003 | 10:14 PM
jibbie's Avatar
ooh thanks. i was just wondering becuase i see alot of engine bays without it. or at least not visible.
Old Nov 20, 2003 | 10:57 PM
My00Camaroz28's Avatar
When I bought a 01'-02' lid on accident for my 00' car, I coudlen't figure out where to put this extra hose. I just mounted it facing upwards a little so it wouldent catch any rocks or anything else, and put this little air filter on the end of the hose. Works fine now.
Old Nov 20, 2003 | 11:37 PM
Another wonder of GM engineering as to why they decided it was necessary to get air from the airbox for 01&02.
I'm actually thinking of cutting the hose and installing a breather filter closer to the smog pump as the hose is rubbing the hood a bit due to my Volant airbox base.
Old Nov 21, 2003 | 10:36 AM
rncotton's Avatar
I put a breather filter on the AIR pump hose and ty-wrapped it to the radiator shroud. But, it looked out of place.
So, I cut my hose and put the filter down by the AIR pump itself. If you want to do this, don't be shocked when your breather filter doesn't want to fit. The AIR pump hose is slightly larger by the air lid than it is by the pump. (or was it the other way around? )
Either way, it wasn't an exact fit. I either sanded the inside of the hose to make the filter fit, or I ty-wrapped it tight to snug the hose to the filter. But, it's out of sight and nobody can see this "extra" hose flopping around.
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
drt
Sep 27, 2015 04:39 PM
generaldave
Sep 25, 2015 06:48 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
