Open element breather causing hi BLMs?
Old Oct 24, 2003 | 12:03 AM
fireman's Avatar
I put an open element K/N breather on my valve cover and plugged the hole on the TB. Is this basically a big vaccuum leak?
I put it back tonight, think this will help?
Old Oct 24, 2003 | 06:36 AM
DOOM Master's Avatar
Definitely get rid of it. All you are doing is allowing unmetered air into the engine, which is causing the O2s to read more oxygen into the exhaust and have the PCM add more fuel. The LT1 is designed to be a closed air system.
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
