Whine on the PS pump.
Old Oct 19, 2003 | 09:51 AM
therealmagyver's Avatar
I have a whine on my pump. Recently had the high pressure line replaced because it was shooting fluid into the fans which in turn sprayed everywhere when the fans came on. I didn't hear a whine when I left (I think...maybe I was happy just to get the hell outta there), but two days later I heard it big time. I bleed the system again with the wheels off the ground etc..but I still hear the whine. The pump I think is working b/c the return line shoots fluid out pretty hard, but I'm no mechanic so something else could be causing that. Someone told me it could be the water pump, but I told him I placed my hand on the PS pump while someone steered and it felt it. Could the water pump send such a strong vibration and the PS pump vibrate also. A whine means the pump is failing or failed. Man I just want to autocross this Saturday and replace the pump the following weekend.
Old Oct 19, 2003 | 11:20 AM
chpmnsws6's Avatar
mine did it all the time like you said till i put on some wd-40 and belt dressing and it went away. that was about 3 months ago and it hasn't went out and i've takin it around the twisties since then with no problems
2QUIK6
Sep 17, 2016 02:31 PM
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
cristian1311
Sep 12, 2015 08:16 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
