help?! (brakes)
Old Oct 18, 2003 | 02:12 PM
mab1436's Avatar
Question help?! (brakes)
im doin my brake pads today, and i took the 2 screws outa the back of the caliper (the 2x 12mm screws on the top and the bottom)
and my caliper wont come off or rotate back its like stuck to the rotor??
im lost, please help
Old Oct 18, 2003 | 02:35 PM
Slappy3243's Avatar
You are talking about the screws that hold the whole caliper itself right? Sometimes you just have to rotate the rotor a bit while you pull the caliper away from it. Be careful though as it will dangle from the brake line if you let it go. If we are not on the same page, check this site out.
http://www.installuniversity.com
Look under install documents and brakes.
-Adam
Old Oct 18, 2003 | 03:41 PM
mab1436's Avatar
Thumbs up
thanks man, rotating the rotor while pullin is wut got it
Old Oct 18, 2003 | 04:52 PM
Slappy3243's Avatar
No problem, I ran into the same problem with my brakes when I was doing it. Glad I could help.
-Adam
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
