machining hub for key
Old Oct 3, 2003 | 12:44 AM
aram's Avatar
Since I have an extra hub sitting around I want to get it machined for a key.. my crank is a stock GM crank. I figured I'd save the shipping hassle of returning the core and get it machined locally. Does anyone know the dimensions or anything else I should tell the machine shop (assuming I find one) when asking them to machine the hub for a key? Also where can I get a key for the hub?
Old Oct 6, 2003 | 06:33 AM
krazwag's Avatar
I just bought one from thunder racing and put it on or I could tell you everything about it. I do remember that if you put a smallbock key in you crank and measure whats sticking out that would tell you how deep to go. Make sure that were they cut it is about the 2 o'clock postion compared to the TDC mark on the hub. It may be hard to find a machine shop that can do that because you have to have a special bit because of the hole being blind. Good luck
Formula Steve
Sep 19, 2023 08:31 AM
Z Power
Sep 19, 2015 11:19 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
Aaront810
Sep 11, 2015 11:24 AM
jackpawt883
Sep 10, 2015 08:53 PM
