advance or straight up?
Old Sep 26, 2003 | 02:05 AM
AdioSS's Avatar
West South Central Moderator
Question advance or straight up?
When ordering a cam, do you folks recommend getting one with a little more duration and advancing it a few degrees, or less duration and installed straight up? Assuming the same heads, lift, etc. they should have similar power bands, right?
Old Sep 26, 2003 | 09:26 AM
SStrokerAce's Avatar
Nope, they will not have similar powerbands.
A larger duration cam will like a little bit more advance. There is a very popular LS1 cam out there that's big in the duration department, but has some advance ground into it to make up for it.
A larger duration cam will like the advance because it will raise the DCR due to the fact that it's moving the ICL and intake valve closing point.
My cams for LT1's are different from the popular C306 and other "large" cams and it all has to do where you put the cam in the motor and overlap.
If you have the same cam, advancing will lower the RPM band, and retarding will raise the RPM band. The stock LS6 cam is a 204/218 on a 117.5 retarded 2.5 degs. The high LSA and retard help make the intake valve closing point pretty late for a 204 duration cam so that's why it makes good power. The OMC from Thunder works under this same principal. Less duration and retard the cam to get the intake valve closing point in the right spot for High RPM power.
Bret
jayblev95
Sep 26, 2015 09:44 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
88IROC_Z
Jul 22, 2015 11:38 PM
