Flywheel balancing...
Old Sep 25, 2003 | 09:17 PM
xxsaint69x's Avatar
Well i called up my local machine shop and asked them if they can balance my new Street Twin flywheel to the old one. He said it’s not possible to balance the flywheel, since the LT1 is externally balanced. BTW why DO WE HAVE TO BLANCE THE STREET TWIN FLYWHEEL? I put my friend’s street twin in, and we just slapped everything on, and had 0 problems with vibrations etc.
SO how are u suppose to balance the flywheel without bringing the whole engine there He said its the only way to do it right.
Thanks
Marcin
Old Sep 26, 2003 | 08:40 AM
bowtiepwr's Avatar
>I had my machine shop zero balance my SPEC fly wheel by it self (on this lathe looking machine) and since they are the ones who built my shortblock then they knew it was already balanced .
Old Sep 26, 2003 | 11:24 PM
xxsaint69x's Avatar
well that really doesnt answear my question....
Thanks
Marcin
Old Sep 27, 2003 | 02:04 PM
thermwood1's Avatar
I haven't had to do this yet, but have done a lot of reading on this board about it.
As far as your friends flywheel being ok with no vibrations, i think is more of a luck thing than anything else. Sometimes the aftermarket flywheels work correctly, and sometimes they don't. Me personally, i would get it balanced to your original flywheel.
I am getting ready to do my T56 swap, so at first i am going with a stock flywheel, since i don't have an existing one to balance from.
And since the LT1 engines are EXTERNALLY balanced, the new flywheel needs to be balanced to the old one. I'm sure if you looked at yours or your friends original flywheel it is weighted somewhere. This is where the externally balancing comes in to play.
The machine shop was correct in a way. The Absolute Best way to balance the new flywheel is by taking the engine in and balancing the flywheel from that. But, since that isn't an option for most people, the new flywheel can be balanced from the old one and work just as good. My .02
Old Sep 27, 2003 | 06:51 PM
bowtiepwr's Avatar
Thanks
Marcin
>I should have also said that SPEC offered this balanced , but the machine shop still had to zero balance it .
Old Sep 27, 2003 | 11:12 PM
xxsaint69x's Avatar
oh well..there is no weights on my flywheel..i guess ill be taking a chance and bolting everything straight up. If it doesnt work no biggie, just drop the tranny again
thanks
Marcin
Old Sep 28, 2003 | 08:18 PM
96speed's Avatar
thanks
Marcin
Externally balanced = weight on the flywheel. If there isn't a weight bolted to the flywheel I wouldn't put it in.
Its not my car, so go for it and let us know what happens .
Ryan
Old Sep 29, 2003 | 10:50 AM
Fast Caddie's Avatar
I just finished swapping the M6 into my car ( I LOVE THIS THING). The flywheel was what i was concerned about. Well, i get the flexplate off and compare it to the flywheel. The counterweights, to my delightful suprise, were at THE EXACT SAME POSITIONS ON EACH. I bolted it in and have no vibrations. I talked to an engine builder in florence before the swap and he said the the SBCs are externally balanced... but since they're as mass produced as they are all the bob weights are calculated to within a certain percentage error before assembly and all the engines recieve the same counterweights in the same positions. Even the Haynes and Chiltons manuals tell you to put the counterweights on the same position of a new flywheel/flexplate if you have to replace the old one.
Old Sep 29, 2003 | 04:36 PM
xxsaint69x's Avatar
http://bellsouthpwp.net/x/x/xxsaint69x/flywheel.jpg
here is what my stock flywheel looks like...i dont see any weights bolted in??
could someone post a pic of a street twin flywheel?
Old Sep 29, 2003 | 05:19 PM
NXz28's Avatar
http://www.street-legal.cz28.com/catalog.html
not a street twin but a SPEC aluminum flywheel. It has weights on the back of it. I was told that the flywheel is going to be balanced from the factory on aftermarket flywheels such as SPEC or mcleod.
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
karpetcm
Sep 29, 2015 10:08 AM
Jake Bialke
Sep 24, 2015 11:31 AM
Bxlt1
Sep 17, 2015 08:31 AM
