Anyone have a wiring diagram for this setup????
Old Aug 14, 2002 | 02:45 PM
Black95Form's Avatar
Question Anyone have a wiring diagram for this setup????
Here is what I want to do:
Activation toggles switch
WOT switch
Fuel pressure safety switch
RPM Activated Window switch
If someone has already done this and could shoot me a wiring diagram I would appreciate the help. Thank you in advance.
Michael
1995 Formula, 355 Forged, ATI Super Damper, M6, B&M Shifter, Spec Stage 3 Carbon Clutch, 4.10, 1LE Drive Shaft, CAI, CC 306 Cam, Pro Mag 1.6 RR's, Hooker LT, 58mmTB, AFPR, 26 lb. inj., Stage 2 Heads, 1LE Elbow, MSD6AL, NGK TR55, LT4KM, !AIR, !EGR, !CAT, BMR SFC, BMR STB, BMR Boxed LCA, BMR Panhard, NX Wet Kit, NX Purge Kit
Old Aug 15, 2002 | 02:39 AM
LT1Z28's Avatar
Wink
You got mail
Later
Mike
95 Z28
383 Cubic Inches
Of NX Direct Port Mayhem
99 GMC Sierra 2500
http://rufidlz.cz28.com/
Old Aug 15, 2002 | 07:34 AM
Thanks.
Old Aug 16, 2002 | 03:55 PM
Loadre's Avatar
I'd like one as well preeetty pleeeease
Old Aug 16, 2002 | 08:46 PM
LT1Z28's Avatar
http://www.rufidlz.cz28.com/NxWiring.JPG
Have fun
Later
Mike
95 Z28
383 Cubic Inches
99 GMC Sierra 2500
Old Aug 16, 2002 | 10:16 PM
Loadre's Avatar
One last Q, where exactly would the purge go in that diagram. And the triangle looking things with the dots on the end are grounds I suppose. Thanks a TON! Brian.
Old Aug 19, 2002 | 03:59 PM
Loadre's Avatar
TTT for above questions
Old Aug 19, 2002 | 09:39 PM
transamtom's Avatar
Thumbs up
Thanks for the link.
Old Apr 4, 2003 | 01:09 AM
craigffb's Avatar
Any reason to use two relays instead of one? I've seen it both ways.
Old Apr 4, 2003 | 12:19 PM
JD30thZ28's Avatar
Nice Diagram Mike
Old Apr 4, 2003 | 12:30 PM
JD30thZ28's Avatar
The pruge is wired sperately It will have it's own switch. The 3 line with the dot are Grounds
warmeck
Mar 22, 2015 10:28 AM
blac94Z
Mar 20, 2015 09:58 PM
4586
Dec 31, 2014 02:21 PM
turbo_Z
Aug 19, 2002 10:50 PM
