Will LS6 injectors lock up under 90psi???
Old Aug 15, 2002 | 08:43 AM
Camaro_58's Avatar
Post Will LS6 injectors lock up under 90psi???
I have the opportunity to pick up a set of LS6 injectors for $100 and wanted to know if I'm better off buying SVO 24# or the LS6 injectors, I believe they're 28#, my biggest concern is the lock up issue. Thanks.
Red 96 Z28, A4, 3.42 gears, K&N CAI, Hypertech air foil, Hypertech PP+ w/scan, GMS MAF, B&M Super Cooler trans cooler, IAT relocate, DRL conversion, MSD 6AL, Flowmaster American Thunder Cat-Back, FLP Headers, BMR STB, 150hp NOS
SLP SFCs, WS6 Shocks and Springs, and Mezier Water Pump in boxes, awaiting installation
Old Aug 15, 2002 | 10:34 AM
wzntme's Avatar
Don't use the asinine factory N.O.S jetting.
85-90 psi is absolutely ridiculous. The jetting I have installed only ramps the fuel pressure up to 55-57 psi. The nitrous gurus Dave Wilson and Mike Graham came up with it and I got the fuel pressure numbers from them. Of course every car is different but I am sure mine is nowhere near 85-90.. I need to get a guage..
laters,
Andrew
'96 Formula
N.O.S 5115-II same as 5176
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
birdblack
Dec 30, 2014 06:59 PM
