Converting NX EFI Kit to a Carb setup...questions!
Old Aug 6, 2002 | 11:31 PM
AutoRoc's Avatar
Question Converting NX EFI Kit to a Carb setup...questions!
Ok, earlier in the year I bought an LT1 Nitrous Express kit from a friend and I used it on my 305 TPI engine. I basically plumed the single nozzle into the MAF sensor behind the heated element. Worked lik a charm...
Now I converted to a Holley 600 Carb and Performer intake. I NEED to spray this combination. Problem lies in the Nitrous jetting, right? The NX kit is for EFI. ALL Nitrous jets should be the same because nitrous pressure is nearly ALWAYS between 700-1200 PSI...no big deal
FUEL PRESURE is what has me thinking. My stock TPI fuel pump is pumping fuel still. It is regulated by a Mallory 3 Port regulator and it sends 6 PSI to my carb.
How would I set up the nitrous kit now? I buy a Carb plate with spray bars in it, right? Then would I need Bigger fuel jets because my pressure is too low?? Would I plumb it before or after the FP regulator?
What is the pressure coming out of the pump if it is on continuously? What is the main line pressure and is it the same at the 6 PSI of pressure coming OU of the regulator to the carb?
Any ideas would be helpful, thanks N2O crew
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com
Old Aug 7, 2002 | 01:24 AM
KTamez's Avatar
<font face="Verdana, Arial" size="2">Originally posted by AutoRoc:
How would I set up the nitrous kit now? I buy a Carb plate with spray bars in it, right? Then would I need Bigger fuel jets because my pressure is too low?? Would I plumb it before or after the FP regulator? </font>
Really its VERY simple as far as the basic installation goes, depending on the plate you get, it will just about bolt-up, where your nozzle was/is.
Yes you will need different larger fuel jets. This will of course depend on what pressure you run to the system. You have a high pressure pump, though I've never dealt with a High Prsssure tune-Up on a Carb Plate myself (Though I don't see why it wouldn't work).
Normally a 5.5-6psi tune-up calls for a square jet pattern (35N-35F, 38N-38F, etc). Nitrous Express normally runs their systems at 10psi (which is what I'd recommend you try to do.
You need to regulate the fuel pressure if you pull the fuel supply from the line before your 6psi Carb Regulator. From there, you have the choice of using the hi=Pressure (~40-45psi) or Low Psi (~10psi) Tune-ups.
I'd recommend ya get in touch with Ricky or someone else at Nitrous Express to help you get it sorted out from there.
Good luck!
Kurtis Tamez
LT4-396.com
97 Z28 LT4-396
94 Firehawk LT1-396
Team NW F-Body
Old Aug 8, 2002 | 08:32 PM
AutoRoc's Avatar
Good man!
Thanks
IgorT.455/406
Mar 12, 2015 03:39 AM
bose
Jan 30, 2015 02:36 PM
Queens94z28
Dec 20, 2014 09:11 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
