wanted 3200 stall
Old Sep 16, 2003 | 02:55 PM
crAzy95z28's Avatar
wanted 3200 stall
hey i need a 3200 stall ASAP new used n e thing that works awsome or just like new!!! i live in the houston area!!! lemme know asap
thanks
randy
Old Sep 16, 2003 | 03:10 PM
VINCELEE123's Avatar
got a 2800 brinton convertor, im in houston as well.
its a nitrous built custom convertor, perfect working condition.
let me know 250$
Old Sep 16, 2003 | 03:25 PM
crAzy95z28's Avatar
umm............is there n e way you could nump it up to 3200???
and what do you mean by nitruos made or w/e?
Old Sep 16, 2003 | 03:36 PM
its got hardend internals,
why do you need a 3200?
just wondering
Vince
Old Sep 16, 2003 | 03:43 PM
crAzy95z28's Avatar
well...cause im going to be doing alot more work to my engine!!!and stuff!! and from what i hear more people have 3200-3600 stalls!!!! if you can gimme some more info on ur stall!!!!! and what i should expect from it!!
Old Sep 16, 2003 | 03:54 PM
ok, i think your cam choice would be the most important with stall selection. will you be using nitrous? the convertor has a harden spring for the nitrous as the torque flashes.
Vince.
Old Sep 16, 2003 | 03:55 PM
crAzy95z28's Avatar
welll.....it all depends...i might go 383 with a turbo kit!! in the near future...but i might throw some nos on it..really dont know for sure!!
Old Sep 16, 2003 | 04:00 PM
a 383 will make tq down low, turbo,nitrous, there both power adders that make a lot of torque down low.
you would want a nitrous convertor for ether application.
most would probobly run a small convertor, it just depends.
post in the power adder section of this board, they could help uderstand a litte more.
the reason i went with a 2800 is because i wanted to spray right out the whole with no back firing
Vince
Old Sep 16, 2003 | 04:37 PM
crAzy95z28's Avatar
well i was going to get a 2800 at 1st...but from everyone i hear they say i should go with a 3200!! sooo....i dunno!!!!
Old Sep 16, 2003 | 04:45 PM
find your peak torque, stall it 400-500rpms before this.
the convertor is a VERY important part in your setup.
tell me your setup. or what you plan and i can help you understand if this convertor is good for you or not
Vince
Old Sep 16, 2003 | 08:22 PM
crAzy95z28's Avatar
sorry!! im just going to go with a 3200 stall...dont think im spraying n e time sooon!! thanks n e wayz
Old Sep 18, 2003 | 06:26 PM
crAzy95z28's Avatar
hey VINCE!!! about that stall you have!! is it good brand or what? or is it a home made stall!!!! and where are you located in houston?
Old Sep 18, 2003 | 07:06 PM
crAzy95z28's Avatar
also....is this stall only for NITROUS setups..or can it bee used for mine..which is nearly stock!!!!
Old Sep 18, 2003 | 08:28 PM
Robert95z's Avatar
whats with all the "!!!!"
anywho, im interested in that converter, whats the STR and condition?
Old Sep 19, 2003 | 01:10 AM
viperkiller's Avatar
if you want a new one pm me i have a guy that builds custom converters. i've had 2 from him they were 2500 stock and a 3500 10 inch both are pretty awsome units. he also makes a billet converter but its like $900
the 10 inch has the same internals as the high $ billet but is around 400. or he could rebuild your stock one with up to 2500 stall.
if your still wondering what stall to go with i have a little experiance for you. i had a 2500 restalled stock converter didnt like it it was a little tight, the 3500 10 inch is very loose performs pretty well and is a lighter so revs quiker. the only thing i dont like is when i go to pass a car but i'm working on a program to fix that .
if your concerned about drivability you can pm me and we could work on a tune that will compensate (sp) for the stall. i.ve learned a few thing to do with the lockup clutch and shift points. you can make stalls pretty streetable with proper tranny tunes.
if you want my advice i would find your cam then find your stall.
