Best way with nitrous?
Old Jun 9, 2002 | 12:53 PM
mjcent922's Avatar
Question Best way with nitrous?
Just wondering thinking of running nitrous on my 94z28.Wet or dry?do I need any fuel or ignition up grades?Nx or TNT seem like the bet two chices out there.I plan on running a 100-150 shot.How many step colder plugs should I use?Also anyone have a price on install of systems?
[This message has been edited by mjcent922 (edited June 09, 2002).]
Old Jun 9, 2002 | 05:51 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
1. wet...safer on a larger shot
2. TNT they have a plate for our lt1's
3. timing retard module is a must
4. plug depends on how much you spray, i would use a ngk tr8 plug, so 3 steps colder
5. i would upgrade the fuel pump
keep in mind my thoughts on this are running safely, especially if you are spraying a stock bottom end. you can always go down to a hotter plug or add more timing if it is running a bit slow, but once you blow a pistion or ringland it is too late. my .02, g'luck
Old Jun 9, 2002 | 06:11 PM
Brent94Z's Avatar
Super Moderator
Cool
Welcome to the Board! Don't forget we also have a dedicated nitrous forum
I'll move this there for you
Brent Franker * Main Page
94 Vortech Z28 * 96 Z28 SS #1655
4th Gen Appearance Modification Guide
F-Body Install & Fix-It Guides
Old Jun 9, 2002 | 09:40 PM
mjcent922's Avatar
Smile
Thanxs Brent!This place is great!
Old Jun 10, 2002 | 03:53 PM
94Z28DOJ's Avatar
Most people run the NGK TR6 plugs or Autolite 103's. Fuel pump is usually good up to a 150 shot, but if you don't have the money for a rebuild you should upgrade it. You and a friend should be able to do the install in about day.
[This message has been edited by 94Z28DOJ (edited June 10, 2002).]
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
nd4spd200
Aug 21, 2015 09:30 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
