bad smells
Old Sep 14, 2002 | 01:40 AM
nick d's Avatar
Exclamation bad smells
i smell gas everytime i am at a lite or after i park....stronge smell...what could be wrong?
Old Sep 14, 2002 | 09:13 AM
Joshs99BlackBeauty's Avatar
Now that you mention that, nearly every time I get out of my car I smell gas. Its not too strong but its still very noticeable.
~Josh~
99 Black 3800 II
KN Filter
SLP Ram Air Induction
Flowmaster 80 Series
3 1/2" Chrome Tips
Home-made Whipser Lid
Replace Cat w/ X-pipe
AC Delco Platinum Plugs
AOL IM: PlatinumSmoke00
My Ride
Old Sep 14, 2002 | 09:45 AM
V6 Punk 93's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Joshs99BlackBeauty:
</font>
Same here.
-Jeff
1993 Camaro [NEW PICS]-3.4 A4, Gray, T-Tops
Mods:
Flowmaster 80 series, K&N Filtercharger,!air silencer,AC Rapidfire plugs,Borg-Warner Select wires,Prime Five Spoke Alloys,Sony Xplod CA650X head unit,Xplod speakers.
Old Sep 14, 2002 | 11:56 AM
ibanez6rg's Avatar
most cars today run on gas
Old Sep 14, 2002 | 12:06 PM
zlightning's Avatar
Stop farting then . On a more serious note I would go get that checked out or try to find the source. I have over 126k miles on my car and don't smell gas at all.
1995 3.4L v6 Camaro FIPK Spintech Cat-back.
Old Sep 14, 2002 | 12:45 PM
All_InTheRED's Avatar
65K miles here........no gas smells.
The only way your gonna have a gas smell on a 3.4 is if the EVAP canister is leaking or the lines and hoses are bad.
Get it checked ASAP!
Max
'95 Camaro V6..BB Triflo quad-tip catback, 180 degree Themostat, WaterWetter, K&N Air Filter, AC Delco Rapidfire Spark plugs, TB-Bypass, BMR Chrome-Moly STB, Front & Rear 1LE Sway Bars, 255/50/16 Eagle GS-C & F1 Steel, Dark Tinted Windows. Fog-lights on when Hi-Beam On Mod done tooooo.
www.home.earthlink.net/~airspeedy2
'99.5 F-250 SuperDuty CrewCab,PowerStroke Diesel, 2wd, Torreador Red, TS Extreme Chip & LPG, BTS Tranny & Converter, Maddog Stage 2 Injectors, Stock Turbo w/aftermarket comp. wheel (35psi boost), Detroit Locker ......14.2@99mph. 436rwhp/869ft.lbs.
...lets just say its not stock.....well DUH!
Old Sep 14, 2002 | 01:27 PM
PitySister's Avatar
<font face="Verdana, Arial" size="2">Originally posted by All_InTheRED:
</font>
hmm, maybe that is why my gas mileage sucks...i get that smell too....
Old Sep 14, 2002 | 01:52 PM
ive got 75k miles...I just never thought anything of that smell, Ill get it checked soon
~Josh~
99 Black 3800 II
KN Filter
3 1/2" Chrome Tips
My Ride
Old Sep 14, 2002 | 03:56 PM
MustangEater82's Avatar
If ya got a 3.4L check out your fuel lines. i remeber chcing ahwile bac that there was a recall on a bunch of 34.Ls I thin in 94-95, something about the fuel lines running near the AIR pump.
I forgot the specifics but I now my car is good because the fuel lines were routed another way, then hte recall listed. It ws only on some 3.4Ls.
Or general stuff chec the little "quoick Disconnect" fitting I ahve heard people have problems with thos eon all GM cars, fuel lines, see if there is anyone top of your intae mainfold, maybe a leay injector?
then the usual check the gas tank, for leaks.
Shouldn't be smelling any gas, I have 118, and do everything form rallyrace(not sanctioned ) to autocross my car and I have no fuel problems.
-Eric
1994 Medium Quaser Blue Camaro 3.4L V6 w/ 5-speed
Stock blocked, boltons only.
15.696@86.22 with a 2.214 60'!
Best R/T .507 Best 60' 2.078
Father's Stock 2000 Navy Blue Camaro 3.8L V6 w/ 5-speed
15.875@88.25 With wheel spin in 1st
3.4L F-body where 15s are fast....
www.fbodyv6.com
www.firebirdv6.com
www.camaroz28.com
AIM: MustangEater82
Old Sep 14, 2002 | 05:44 PM
Perfecto's Avatar
Wink
Definatly check the fuel injecters. My ex girls car smelled bad of gas and thats what it was. It was barely spraying a little mist so check closely
Black 94' 3.4l Camaro A4
Old Sep 17, 2002 | 08:38 PM
nick d's Avatar
wow a decent amount of people smell gas. yea i will have it checked out i dont wana blow up. i looked for leakage but no sigh's. ok thanks guys
Old Sep 18, 2002 | 12:13 AM
do we have fuel evap canistors on 3.4Ls I know I did on my 2.8L, I fixed a problme with that, jsut a charcoal filter, right? I know thats known to cause fuel smells.
but guys you may want ot look into the recall thing I was tlaking about, I don't rember the specifics, but I know its somtehitng about bad fuel lines, and how they are routed and it affected alot fo 3.4Ls, but no all of them. I checked it out on my car nd I didn't have it my fuel lines were routed differently then what it wa said caused the problem.
Old Sep 18, 2002 | 12:37 PM
94Camaro6cyl's Avatar
Definatly check all your lines and hoses ASAP....
jwade88
Jun 14, 2015 09:38 PM
z28cam1993
May 29, 2015 10:17 PM
kxrawx
May 25, 2015 08:29 PM
Lt4Z2897
Mar 26, 2015 03:02 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
