Brake Problem
Old Sep 2, 2002 | 11:39 PM
95V6TN's Avatar
Unhappy Brake Problem
I have a 95 V6 and my ABS INOP light keeps coming on. Last night I was driving and when i applied the brake, the Low trac light would come on and the brake pedal would push almost into the floor. It didnt matter whether i was in a parking lot or on the street it would still happen. Now today it only did it one time and the ABS INOP light did not come on. When I got ready to drive home tonight, the ABS light came back on. Can anyone shed some insight as to what the problem could be?? thanks!!
Old Sep 5, 2002 | 01:55 PM
nothingeined's Avatar
have you checked your emergency brake? if its a up a little it cuts off your abs. or you could also use some new brakes. hope it helps.
2000 Camaro
whats a mod?
Old Sep 5, 2002 | 04:29 PM
MustangEater82's Avatar
look at your AMp guage, maybe you are having battery or alternator problems, if you have any charging problems it will set off your abs inop light.
Check your battery and alternator connections, also.
-Eric
1994 Medium Quaser Blue Camaro 3.4L V6 w/ 5-speed
Stock blocked, boltons only.
15.696@86.22 with a 2.214 60'!
Best R/T .507 Best 60' 2.078
Father's Stock 2000 Navy Blue Camaro 3.8L V6 w/ 5-speed
15.875@88.25 With wheel spin in 1st
3.4L F-body where 15s are fast....
www.fbodyv6.com
www.firebirdv6.com
www.camaroz28.com
AIM: MustangEater82
Magenta_Hearts
Mar 25, 2015 10:24 AM
dluna333
15
Mar 13, 2015 12:30 PM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
