2000 or 2001, which should i get!
Old Sep 14, 2003 | 01:16 PM
Amit's Avatar
ok fellas,
the time is finally near.
i am starting to look for an ls1 SS.
now i really want a 2001 camaro SS but the 2000's are cheaper.
but as everyone knows, each year the automaker improves over the previous year.
i read that stuff like piston slap, excessive oil consumption, coolant leaks.. are not as common on 2001's as they are on 2000's. is this true?
i tried doing a search but i didnt get mush help.
Old Sep 14, 2003 | 01:23 PM
Mister Will's Avatar
I am not sure about improvements of piston slap, oil consumption, or collant leaks. But a big difference between 2000, and 2001 was the installation of the LS6 intake manifold on all LS1 engines. This provided more low end torque with an increase in HP. If I had a choice I would go for the 2001.
Old Sep 14, 2003 | 01:28 PM
Amit's Avatar
werd. but i will be modding it.. so i dont really care too much about which car has more power.
what i do wanna know is things like, what better improvements were made on the engine, rear end, tranny, brakes, suspension.
i think the o1's use a zo6 clutch right?
and the o1's have no egr?
Old Sep 14, 2003 | 01:41 PM
I am 75% sure that the 2001 had the Z06 clutch, but I would wait for another confirmation.
The LS6 manifold has no EGR. Hence the EGR was removed for all LS1s from 2001 and beyond.
Old Sep 14, 2003 | 02:29 PM
Lan01z's Avatar
//what i do wanna know is things like, what better improvements were made on the engine, rear end, tranny, brakes, suspension.
It has the same rear end, same tranny, same brakes and suspension. The 01 has a better oil cooling system and the ls6 intake for a supposed 10hp gain. I figure, why spend the money for the ls6 intake for a 2000.. just get the 01. Other unimportant things the 01 has is more sound dampening to make a quieter cabin (which makes hardly any difference when you slap a new muffler on) You're pretty much comparing the same car, other than the intake, the oil cooling and the clutch.
Old Sep 14, 2003 | 02:33 PM
chpmnsws6's Avatar
get an 00 and put an ls6 intake on it....... that just gave you enough extra cash for you to get a cam and headers
Old Sep 14, 2003 | 03:11 PM
Amit's Avatar
what about the piston slap and the excessive oil consumption?
Old Sep 14, 2003 | 06:02 PM
Omega9's Avatar
Thumbs up
My 01 WS6 doesn't have piston slap, and uses absolutely no oil. Its unreal.
Old Sep 14, 2003 | 10:06 PM
Amit's Avatar
i guess i should stick with an 01
Old Sep 14, 2003 | 10:52 PM
chuck's Avatar
I could not be more pleased with my '01, and would suggest them to everyone.
Old Sep 15, 2003 | 08:34 AM
DS01Z28's Avatar
'01. And you won't need a different intake, cam, and headers! No oil waste either.
Daryl
Old Sep 15, 2003 | 10:14 AM
Black01_Z's Avatar
My 01 does burn a little oil. I dont see why you shouldnt do a cam or headers on one though. The manifolds are the same on an 01 as an 00. I believe the 01+ got a slightly different cam, but they could still more than benefit from a cam swap. The big plus is no EGR and AIR restriction plus an LS6 intake.
Old Sep 15, 2003 | 12:56 PM
95GRNZ's Avatar
Cool
Well said.
My 00 does not consume any oile between oil changes (3-5K miles), no piston slap, no coolant problems and made 297hp/309lb.ft to the rear wheels when stock.
I have nothing to complain, I guess...
If money is not an issue to you, then why not get the newest possible?
TS
Old Sep 15, 2003 | 03:49 PM
silversupersport's Avatar
my 00 SS has no coolant problems and doesn't have any piston slap but does use about a liter of oil every 5000 kms, but then i dont drive like a grandma either.
Old Sep 16, 2003 | 02:33 AM
Amit's Avatar
i found a 2000 SS
with 35000kms.
thats about 21 000 miles.
its fully loaded.
NBM , M6
and its going for 23000 cdn.
thats about 16000 us.
originally im looking for a RED car..
but the NBM isnt too bad. what do you guys think about NBM?
