96 3800 II noise
Old Jul 24, 2002 | 08:08 PM
dissonance's Avatar
Post 96 3800 II noise
I have a 96 camaro with a 3800 II; I have only had it for about 6 weeks.
There is rattling noise from the motor. At idle it’s noticeable in the car, if I bring the rpm’s up to around 1k the noise almost goes away. It sounds like something is loose, I was thinking it was a pulley but I oiled all of them and it still did not go away. The alternator is newer, a least it still looks new.
Any ides would be great. Thanks
Old Jul 26, 2002 | 03:32 PM
V6white98's Avatar
No offense but all you have really eliminated from the possibilities is the exhaust, a little more detail. Can you tell what area its coming from, what does it sound similar to?
my car-Black with black leather interior 99 Camaro SS, A4, T-tops and lots of options
my old car-(sold to my brother 7-13-02) white 98 V6 A4, leather, t-tops, exhaust and intake mods
Old Jul 28, 2002 | 07:00 PM
NAVY99's Avatar
i have the same problem and i think that it is something to do with a piece of the exhaust rattling. One solution, replace it!
1999 Navy Blue Camaro 3.8L v6
Old Jul 29, 2002 | 07:40 PM
dissonance's Avatar
I don’t think it’s an exhaust leak, I will check but it just does not have tick sound. It’s a rattling like thin metal taping against each other. Is there a heat shield around the manifolds? What about the transmission area? The car is stock, with 83,000 miles on it
Old Jul 29, 2002 | 07:49 PM
JB_96RS's Avatar
Talking
Mine has a rattle. Its the exhaust shakin inside of another pipe right along the driveshaft. It doesnt sound like it has a leak but its loose. It does it in traffic when I let off of the gas the RPM's are around 1500. But if I hold it @ 3000 it goes away. Crawl under there and grab the pipe (cold of course) and move it side to side..just a thought.
Old Jul 31, 2002 | 05:06 PM
V6white98's Avatar
Sounds like you need to replace the muffler bearing.
Old Aug 5, 2002 | 11:28 AM
dissonance's Avatar
Wink
Well that’s the thing i already replace the muffler bearings (every 10k mi)
I drove the car last night and hooked up my autotap to it and i was getting knock bad!!! 7 degrees but I could not hear any noise/pinging coming from the engine. I am going to take a look at the plug and wires soon, test the plug wires for high ohm’s
Any other idea’s would be great
Old Dec 6, 2002 | 09:41 PM
95 3.8's Avatar
harmonic balancer, I have the same problem. its on the crank pulley. check if rubber is torn or missing.
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
colts0455
13
Aug 7, 2015 09:15 PM
colts0455
Jul 7, 2015 07:19 PM
