cam info
Old Sep 9, 2003 | 11:08 AM
kevinz85's Avatar
cam info
Does anyone have the specs for the cc306 cam and would this work well with a carb.
Old Sep 9, 2003 | 12:05 PM
82355's Avatar
Comp Cams 306 (230/244 .544/.576 112 LSA)
I would go for a narrower LSA for a carbed application.
Oh sorry, my lift numbers were with 1.6 rockers. Look at the numbers posted by Marc
Martin
Old Sep 9, 2003 | 12:10 PM
Marc 85Z28's Avatar
Advertised duration: 290 intake/307 exhaust
* Duration at .050 in. cam lift: 230 intake/244 exhaust
* Gross valve lift: .510 in. intake/.540 in. exhaust
* Lobe separation: 112 degrees
* RPM range: 2,000 to 6,000
Did you by any chance read another post boasting about the CC306? That is a fairly radical street cam, requiring deep gearing and a loose converter (if auto) and good heads. The LT1 guys seem to like them, but judging by your screenname and the carb question I'm assuming you don't have an LT1. Unless you've swapped a 350+ inch motor into your car with the drivetrain mods to support it this is too much cam.
And yes, it will work well with a carb. It's the rest of the motor and car you need to be concerned about.
Any more info on your setup?
Old Sep 9, 2003 | 12:36 PM
kevinz85's Avatar
I am using a 350 out of my 90 iroc which is wrecked I am making it a 383 I plan on using topline or edelbrock vic. jr. goal ultimately is 500 hp if you have any suggestions i willing to listen this will be a street/ strip car
chuyz28
Jan 15, 2015 04:14 PM
Not Dave
Dec 11, 2014 06:32 PM
bernie1951
Dec 10, 2014 10:03 AM
Queens94z28
Nov 20, 2014 06:03 PM
Elcojoe
Nov 17, 2014 10:27 PM
