A/C problems?
Old Jul 9, 2002 | 05:37 PM
Perfecto's Avatar
Question A/C problems?
My air conditioner gets cold but it cuts out when I accelerate. The fan shuts slows down and sometimes shuts off completly until I let off the gas. What is wrong. Loose belt, bad a/c or electrical.
Old Jul 9, 2002 | 06:32 PM
TheYetti's Avatar
it is supposed to do that. all camaros and firebirds do, it sucks especially in 115 degree wether like in az. anyone know how to make it stop??
Justin
1996 Camaro
B&B Test Car
Soon to be LS1
Need a V8!!" He might have turetts syndrome, we are looking into it."
Just look at the site!
http://theyetti.cz28.com
[This message has been edited by TheYetti (edited July 09, 2002).]
Old Jul 9, 2002 | 08:23 PM
Marky82's Avatar
Mine doesn't do that
Old Jul 9, 2002 | 09:59 PM
fourthgen9534's Avatar
a friend of mine has a 95' 3.4 'maro just like mine, except an A4, and his does that, but mine doesn't
Red '95 camaro. 3.4l M5
Crane compucam2030 K&N FIPK. Flowmaster catback. ASP crank pulley. !cat !egr !air TB bypass. 1pc. D/S. Taylor wires. Fan switch mod. urethane Tranny mount & TQ arm bushing.
Red painted interior and brakes. Tint. Flat black rear "camaro" panel
Pioneer Premier DEH713 HU
Planet Audio 6 1/2 components.
mtx thunder 102
16.37@84mph<==1st time at the track
here she is
Old Jul 10, 2002 | 01:23 AM
kevs1993's Avatar
My Camaro does not do that not all Camaros do that!! Not sure what it is, sorry i could not help KEVIN
Old Jul 10, 2002 | 12:09 PM
Perfecto's Avatar
Talking
I decided to check things out myself. I took off the bottom part of my dash and looked around. I found what looks like different colored tubes or wires connected to round plastic boxes, look like they might be fans. I found one tube that wasn't on all they way so I pushed it back on. I did this with the rest off them. Now it works just fine. I hope that was the problem not just a coincedence. Hope this helps you guys. Later.
Old Jul 26, 2002 | 01:36 AM
fbird95's Avatar
Theres also this a/c check valve on the pasenger side of the engine compartment. this controls the direction of the vents inside the car. If this peice developes a small crack in it depending on the temperature it could expand and loose pressure causing one of the symptoms above.
Old Jul 26, 2002 | 10:13 PM
does everyone that has this problem have an auto.?
Old Jul 29, 2002 | 12:19 AM
mm2harrell's Avatar
dude, it's not a problem with your a/c, it's a performance mod on your car that cuts out the a/c out wide open throttle. i bet if you lift the hood and have someone in the car on the gas. every time you hit wide open throttle the serpentine belt keeps spinning but the a/c pulley stops. don't be afraid. it's a performance thing. sorta like when people take out their a/c to take load off the crank pulley. i'm not sure which camaros have it. but my 97 30th anniversary camaro does it. and my 93 trans am doesn't.
Fear the raven.
HectorM52
Jun 23, 2016 08:42 PM
HarleyZ28
Oct 5, 2015 06:23 AM
alphaauto
Feb 5, 2015 05:25 PM
Duke
Sep 3, 2002 02:48 PM
IROC5.7TPI
Aug 13, 2002 01:29 PM
