SPRAYING A 98 3800
Old Jul 27, 2002 | 09:06 PM
stjames69's Avatar
Question SPRAYING A 98 3800
Has anyone here used N2o on their 98 + v6 fbody? If so, what setup you running? What strength? Any concerns that are particular to our cars?
Cheers
Ryan
1998 3.8 Camaro Black
- Y87 Package
- 5 Speed T-tops
- Flowmaster Exhaust
- Jet Performance Stage2
- Accel 9000+ wires
- 160 Stat
- 18x9 Mille Miglia 11-2 Wheels with 235/40z18 front, 275/35z18 Rear Yokohama AVS Sport Rubbers
- Xenon Body Kit
- K & N Filter
- Autometer Pro Shift
Old Jul 27, 2002 | 10:02 PM
mm2harrell's Avatar
I'm spraying my 3800 but it's a 97. I use a zex 100 horse dry kit with the nozzle about 6 inches in front of the throttle. the only thing i've had to change so far is the clutch.
Fear the raven.
Old Jul 27, 2002 | 10:52 PM
nikkev's Avatar
Exclamation
The main thing to remember about nitrous is that you need to make sure you never lose your fuel supply.Nitrous minus fuel equals BOOM! So either run a wet kit or make sure your fuel system is up to par.I ran a 100hp shot on my '95 3.4 and never had any problems with that shot.Also you never want to shoot the juice at anything less than full throttle.So a basic kit should include at least:
-Fuel pressure safety switch
-Full throttle switch
There are a lot of extras you could get but those main safety items should be there.Good luck.You also might want to check out the nitrous forum at www.firebirdv6.com and have fun!
Kevin
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Taylor 10.4mm wires,!EGR,!FRA,SLP Lid,MAF Ends,IAT Tricker,TB Bypass,Manual Fan Switch,and Dynomax Cat-back
BMR STB and Sub-frame Connectors
Pics
Old Jul 28, 2002 | 03:21 PM
shortdog273's Avatar
100 shot on a 3.4 is alot
2000 BLACK FIREBIRD 3.8 A4, (Stock 3.42 Gears, LSD, W68 Pkg), 160* Powerstat, Whisper CAI & Lid, K&N Filter, 3 Catco Highflow Cat, 3in. S Pipe, 2.75" Dynomax Catback, Sprint Springs, BMR STB, LCAs & Brackets.
MOFBA/FASTLOUIS Member... 1/4 Time: 14.981 @ 89.66 MPH
Old Jul 28, 2002 | 04:31 PM
nikkev's Avatar
Cool
<font face="Verdana, Arial" size="2">Originally posted by shortdog273:
</font>
Yeah,but she took it like a champ! I had my kit on there for over a year and Tim LeGros had a 90hp shot on his '95 3.4 for right around 3 years I think.Neither of us had any problems from using that high of a shot.The 3.4 has a very strong bottom end,the only thing that's weak is the pistons themselves.And like I said above,throw enough fuel in with the nitrous and you should be OK.
Kevin
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Pics
Camaro/Firebird Birthday Bash
Old Jul 28, 2002 | 04:53 PM
That's pretty good. I was told anything under a 100 shot should use the dry kit. I'm looking into it.
2000 BLACK FIREBIRD 3.8 A4 (Stock 3.42 Gears & LSD), 160* Hypertech Powerstat, Whisper CAI & Lid, K&N Filter, 3 Catco Highflow Cat, 3in. S Pipe, 2.75" Dynomax Catback, Sprint Springs, BMR STB, LCAs & Brackets.
Old Jul 28, 2002 | 05:07 PM
nikkev's Avatar
Exclamation
</font>
Are you sure they said should or that it would be safe?It will never hurt to run a wet kit,just make sure the nozzle is jetted right for the amount of nitrous you are using.If the fuel injectors lock up on a wet kit,the car will be OK.If the fuel injectors lock up on a dry kit *BOOM*. It will not hurt the motor any if the nitrous solenoid locks up and you only spray fuel into the intake,the car will just run a bit rich.That's why I always suggest a wet kit to nitrous users.I am getting another one in January when I get back from Germany to go on the Z.Later.
Kevin
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Pics
Old Jul 28, 2002 | 05:09 PM
nikkev's Avatar
Exclamation
Oh yeah:
IF YOU USE NITROUS YOU HAVE THE POTENTIAL TO DAMAGE YOUR MOTOR!! Please don't shoot a 150hp shot and then say that I told you it was OK.Please take my advice at your own risk.
Kevin
Old Jul 28, 2002 | 08:52 PM
mm2harrell's Avatar
i would use the dry kit anyway. wet kits have more of a tendancy to cause intake manifold backfire.
Fear the raven.
Jeff1904
Jun 5, 2016 05:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
RX Speed Works
Jul 24, 2015 02:25 PM
