Torque Arm Mount (T56 Swap)
Old Sep 8, 2003 | 03:47 PM
Black6SpdTA's Avatar
I haven't yet started the install (shifter still hasn't arrived) but just learned I needed the Torque Arm mount from the 4th gen. Is there ANY way to reuse the T5 mount? Thanks
-Rippin
Old Sep 8, 2003 | 07:49 PM
camaroz28racer2's Avatar
Yeah re use it by bolting it on, whoever said you needed a 4th gen mount is a moron, I think i saw who it was on tgo, someone who keeps posting mis-information.
Old Sep 8, 2003 | 08:03 PM
mrr23's Avatar
well go to www.spohn.net he sells the proper crossmember for the conversion. you can use the 4th gen one but have to cut and weld it to a different angle to fit.
Old Sep 8, 2003 | 08:19 PM
doug791's Avatar
wow i dont think that had any relevance to the topic at all
Old Sep 8, 2003 | 08:21 PM
mrr23's Avatar
yep you are correct. missed the torque arm part didn't I? i was obviously thinking of the wrong part.
Old Sep 9, 2003 | 12:42 PM
TheGreatJ's Avatar
It's somewhat relevant.....if you get the Spohn crossmember and torque arm you don't need the factory T-56 torque arm mount.
I've heard from a couple of guys that the T-5 mount will bolt onto the T-56, but I don't know if this is accurate because I haven't had any dealings with a T-5 mount. My car started life with a 700-R4.
Old Sep 9, 2003 | 02:48 PM
Could you get just the crossmember then later get the torque arm? The picture on the site makes it appear one solid piece?
-Rippin
Old Sep 9, 2003 | 04:31 PM
The T5 mount bolts to the T56, end of story, dont care what you want to guess at, you dont need a 4th gen torque arm or mount or whatever, dont wanna hear it, stock T56 bellhousing, regular sbc, use any of the crossmembers designed for the OEM T56, the normal spohn crossmember does not come setup for the tubular torque arm, you may be able to buy that from them and then the arm later however im not sure if they will do that.
Old Sep 9, 2003 | 05:18 PM
TheGreatJ's Avatar
Yeah you'll have to ask Steve about that one. You get the crossmember when you buy the torque arm usually....I'm not sure if he'll sell them seperately. I kinda doubt it but you won't know unless you ask.
Old Sep 10, 2003 | 07:19 PM
IrocinthatZ's Avatar
Ok well im not a moron and i had to get a torque arm mount from a 4th gen to get it to fit on my iroc....i did have a 700r4 though.
Mar 13, 2016 03:39 PM
canbaufo
May 5, 2015 03:43 PM
Jason Short
Jan 19, 2015 06:34 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
