how to change pontiac ignition switch
Old Sep 8, 2002 | 09:36 PM
phoenix916's Avatar
Post how to change pontiac ignition switch
It's not a camaro or firebird but should be the same as firebird. I am working on my father inlaws 78 Pontiac Catalina and need to get the ignition switch out. I currently have the steering wheel off and the column dropped. Does anyone know how I get the ignition switch out? How do I get out the metal plate that grabs the steering lock? Any help would be great, Thanks in advance.
Brett
Old Sep 9, 2002 | 10:36 PM
TJS69's Avatar
Smile
From what I've heard, (never removed one) there should be a small hole, in the column, near where you insert the key. You are supposed to be able to remove the assembly after you insert a paper clip end (or other small object)in the hole to release it. No need to remove the wheel.
99
Old Sep 9, 2002 | 10:59 PM
phoenix916's Avatar
<font face="Verdana, Arial" size="2">Originally posted by TJS69:
99
</font>
That's how FORD'S work. I finished messing with it today and it's worse than when I started so know I have to change the column.
Old Sep 13, 2002 | 11:54 AM
patgizz's Avatar
whats so bad that the column needs changed?
the switch is a PITA, gotta remove the lock plate and the turn signal switch to get to the screw that holds it in.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
robcarnut
Mar 20, 2015 03:40 PM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
whuzizname
12
Jul 22, 2002 07:52 PM
