Injector offsets
Old Sep 7, 2003 | 10:49 AM
fireman's Avatar
Injector offsets
I have 24lb SVOs and my offsets are at the stock setting. Should I change these to the proper settings for those injectors?
Old Sep 7, 2003 | 10:55 AM
Dan K's Avatar
Try stock and the SVO offsets and see what happens. You might find the car runs better with one or the other.
Old Sep 8, 2003 | 01:13 PM
ZPaul2Fresh8's Avatar
I maybe wrong but I though SVOs were rated at a higher fuel pressure? If so, then the stock 24# would be better.... no?
Old Sep 8, 2003 | 06:54 PM
Dan K's Avatar
No. He's asking about the offsets...not the injector constant.
Old Sep 8, 2003 | 09:40 PM
madwolf's Avatar
FWIW, I've always had better luck with the stock offsets on SVO injectors.
Old Sep 11, 2003 | 07:38 AM
I understand that, but dont the RP 24# flow better than the SVO 24#s? I read somewhere that SVOs flow less than stockers since they are rated at higher PSI???
Old Sep 11, 2003 | 11:31 AM
383Z4ME's Avatar
It's the other way around. The SVO's are rated at a lower pressure 39.5 (I think) and stock F-Bodies run 43. The SVO's will have higher output at stock F-Body fuel pressure.
Old Sep 11, 2003 | 11:53 AM
JSK333's Avatar
Oddly enough, same here. With my injector constant at 31.68 with my 30# SVOs, I get very close to 128 BLMs at idle. If I change the offsets (raise them like they are rated) the BLMs start to take a nosedive... strange.
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
form94
Sep 23, 2015 07:30 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
