Speaker is jacked, what to replace it with?
Old Sep 7, 2003 | 12:32 AM
Ferocity02's Avatar
Arrow Speaker is jacked, what to replace it with?
I finally figured out that the middle speaker on the passenger side has gone out. I need something halfway decent to replace it that won't cost an arm and a leg. Any suggestions on what to get and where to get it. Oh, and are the middle speakers only supposed to put out bass? Thanks.
Old Sep 9, 2003 | 01:43 AM
fiftyonefifty's Avatar
JL Audio 6w0. Technically it's supposed to have a box, but using it in the mid section of a camaro should sound good, and it would probably increase your bass pretty well in the car since it's a subwoofer.
other than that, you might check eBay for a good deal on some MB quart mids
Old Sep 9, 2003 | 12:24 PM
firebirdude's Avatar
Re: Speaker is jacked, what to replace it with?
This makes me think that you have the monsoon system?
Old Sep 9, 2003 | 05:13 PM
moonpetal38's Avatar
If it is a monsoon system, won't this mean that speakers are needed with special requirements? Or get factory's. I ask this question because I have a passenger side speaker that rattles. I have been asking around town but get the same answer. Get factory's. I would like to get something better than factories but can't seem to get a straight answer about it.
Old Sep 9, 2003 | 05:59 PM
Here's some good reading material.
Old Sep 10, 2003 | 05:16 AM
Thanks!
Old Sep 11, 2003 | 01:03 AM
Ferocity02's Avatar
So will a 6.5" 2ohm sub work, and not fugg up the rest of ym system? Are they hard to find? Will Best Buy or Circuit City have them? Thanks
Old Sep 17, 2003 | 02:16 PM
camaroFl's Avatar
I have same problem with my speakers they but I told you have to buy factories it suxs bad I wish somebody could help us this is bs only tied to factory crap speaker that can't even handle the power dammit wb if you can cya I need help! they cost 75 for the fronts dor speakers
Old Sep 17, 2003 | 02:54 PM
Image Dynamics makes a 2 ohm midbass speaker. But, as I've stated before, powering them with the stock amp is a federal offense.
Old Sep 17, 2003 | 02:58 PM
camaroFl's Avatar
no I need the door speakers
Old Sep 17, 2003 | 04:04 PM
I was repling to Ferocity02......since this is his topic. But Image Dynamics also makes 2 ohm component systems as well.
Old Sep 17, 2003 | 09:22 PM
Rogue Leader's Avatar
Rockford fosgate makes the RFP4406 6.5 inch sub.... Im considering picking em up and trying em, they are SVC 4 ohm tho...
Old Sep 20, 2003 | 11:05 PM
Ferocity02's Avatar
What is the part number for the stock middle speaker? Thanks
Old Sep 27, 2003 | 08:34 PM
Ferocity02's Avatar
TTT
Old Sep 29, 2003 | 11:16 AM
Coolformula's Avatar
I have a aftermarkter HU, I don't see NO amp in my wheel while, so I assume somebody trahsed before I got teh car, my new HU is 4 ohms so I should be able to replace the speakers not without a promblem right???
