Help with Zex kit
Old Sep 1, 2003 | 08:27 PM
nutts 96 ws6's Avatar
Help with Zex kit
Ok I have everything hooked up with a rpm window switch and I am pretty sure that everything is hooked up correctly. The problem is my friend told me that there should be a red light thats on when the box is on. But since the window switch is there it shouldt come on until 3000 - 5600 rpms. So I turned the ignition on to the car, pushed the throtlle all the way down and pushed the button. Then I started the car and pushed the throttle down and at 3 grand the green light flashes. Is it supposed to flash? Also there is not any nitrous that comes out. Any ideas?
Thanks.
Old Sep 2, 2003 | 02:27 AM
lt1form's Avatar
A ZEX nitrous kit has to "learn" your TPS signal, If I remember from installing my friends you have to hook it up then a certain color comes on and someone has to be in the car and pushes the accelerator down and up a few times with the key on.
And if I remember right the light on the main ZEX box will change color when it "learns" you TPS signal when you move the accelerator pedal.
Old Sep 2, 2003 | 07:43 AM
lt1 form,
Do you know where I can find instuctions on how to set it, or which color of wire it is for the tps. I've looked on zex and dint really find anything that specific.
Thanks
Old Sep 2, 2003 | 06:38 PM
lt1form's Avatar
Sorry , I asked my friend and he doesn't know where the instructions are at. I will ask him again and see if he can find them, check with www.zex.com and call thier 1-800 number on the website they are really nice and helpfull.
Old Sep 2, 2003 | 10:08 PM
lt1form,
Thanks for looking into it, but I found out that on my relay I had a couple wires mixed up and just switched them around. Works good now. Thanks again.
lt1xondeck
Mar 18, 2016 07:22 PM
karpetcm
Aug 14, 2015 03:02 PM
RX Speed Works
Jul 24, 2015 02:25 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
Jlo
Jul 22, 2015 05:00 PM
