Enigne Blueprinting
Old Jun 28, 2002 | 08:23 AM
kissel's Avatar
Post Enigne Blueprinting
What exactely is engine blueprinting? Is there a standard way to do it and what is involved? I am having my engine redone and they mentioned blueprinting.....
any ideas?
kissel
Old Jun 28, 2002 | 06:39 PM
MadMike's Avatar
Blueprinting can mean 1 of two things:
They put your engine together like normal, say they blueprinted it and charge you extra.
or
Blueprinting: Meticulously and exactly assembling an engine to optimum clearances and torque.
So, a "real" blueprinted engine will have a sheet of paper with it indicating the clearances and torque values of every component that's been blueprinted (ring gap, valve clearances, bearing clearance, main cap torque, etc...).
It won't be "close enough".
It'll be the exact value or measurement.
Winston cup engines are blueprinted. If you're a thousandth off on a clearance, the thing blows up. This isn't as critical on a regular street engine, which can simply be assembled with care and to the correct specs.
Another example:
The factory spec on a bolt might be 65 - 70 foot pounds. Anywhere in there is fine.
A blueprinted engine will be set at 68 # and it'll be noted. And every other related bolt will be 68#.
This is why blueprinting something costs extra.
Old Jun 29, 2002 | 08:12 AM
kissel's Avatar
thanks mad for the reply, much appreciated.
kissel!
GrnHornet
Jan 14, 2004 06:46 PM
93ZM6Tally
Jan 13, 2004 08:28 AM
S.J.S.
Oct 21, 2003 02:02 AM
DarthIROC
3rd Gen / L98 Engine Tech
Jun 23, 2003 12:34 AM
walter1234
Oct 28, 2002 12:05 PM
