Whats the biggest Crank that a 400 sbc can take?
Old Jun 19, 2002 | 01:39 AM
RobZ's Avatar
Post Whats the biggest Crank that a 400 sbc can take?
Well I have right now a bare 400 sbc.I will be given a 3.800 scat crank from a buddy of mine.My question will it fit on a 400 sbc?
Old Jun 19, 2002 | 06:34 AM
texlurch's Avatar
thats about the longest stroke you can fit in a stock block, and you will probably have to use a small base circle cam to clear the rods. You will still have to do some clearancing on the pan rails, and the bottom of the cylinders. I would double check for piston availability also, although you could get custom ones built.
Texlurch - 68 Camaro (Just a little ol' LT1 with a Hot Cam, I SWEAR
" a little spray never hurt anyone, spank you very much!"
or the old standby:"I came here to race, not sell real estate. You ain't scared, is ya?"
Old Jun 20, 2002 | 07:21 AM
gs400tx's Avatar
they can go to 434 with a 4" stroke.. but its a pain. Check into stroker clearanced rods. Most H beams come clearanced. Some reduced base circle cams are not much smaller than standard and will often times not be enough clearance. I ended up with a .9" basecircle on a 3.75 stroke but i am using I beam rods.
Old Jun 21, 2002 | 04:46 PM
RobZ's Avatar
thanx for the info
Old Jun 22, 2002 | 01:37 AM
texlurch's Avatar
All the 434's I've seen used aftermarket or Bowtie blocks, and it was still close. On a stock block you have to be real careful not to hit water. I have also had the block poured with Hard block before we started grinding, just to be on the safe side. But each block has to be checked to be sure.
SpeedJunkee
Jan 27, 2015 10:02 PM
pecaspickles27
Wheels and Tires
Jan 20, 2015 02:31 PM
Lederman1976
Nov 30, 2014 05:21 AM
