holley stealth intake
Old Aug 14, 2002 | 08:35 PM
the maroman's Avatar
Post holley stealth intake
who has one and is it better than the big mouth intake from tpis? is the holley worth it because ive heard that you lose 30horses down low to gain 60 in the upper rpm range?let me know
Old Aug 15, 2002 | 12:43 PM
OrangeIROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by the maroman:
who has one and is it better than the big mouth intake from tpis? is the holley worth it because ive heard that you lose 30horses down low to gain 60 in the upper rpm range?let me know</font>
yes and yes
TPiS Mini-Ram is also a very good intake, i would recommend this one to you..
1988 Camaro Iroc-Z
Medium Orange Metallic
14.04 @ 97mph
Old Aug 15, 2002 | 03:24 PM
RedIrocZ-28's Avatar
I would go with the Stealth Ram. The Mini Ram is the same thing basically, but costs about 4x as much. There are a lot of guys bolting a Stealth Ram on a stock motor and gaining 60 horse ar a certain RPM. In fact... I plotted a graph of the stock TPI unit versus a Stealth Rammed L98. I'll post a link to it. The TPI was very flat and kind of dome shaped. The Stealth Ram is the one that just climbes and climbes past 5200.
EDIT: I should mention that this pic is blurry so... The TPI starts above the Stealth Ram for hp at 3200 but the SR soon overtakes it and climbes all the way to 5200 where they let out because the TPI was making nothing up there but the SR was still pulling. Just take a look.
http://briefcase.yahoo.com/bc/diablo...t%3f%26.dir=/D iablo%2527s%2bphoto%2balbum%26.src=bc%26.view=l
-Brad C?
355ci '89 Iroc-Z Red, T-tops, power everything, A4,New 10 bolt w/ 3.73's
Trans-Go shift kit Corvette Servo,Accel 8.8mm wires,Flowmaster 80 series ,K&N's, !MAF Screens, Hollowed out airboxes,homemade Subframes. Kieth Black pistons 10.3:1, Comp Cams 270H (.495/.502 218*/224* 110*LSA) & valve springs, SLP 1 3/4" headers, TCI 2400 stall, Dual Roller timing chain, 2 3/4" I-pipe.
Full street trim best run:14.799/mph:93/60': 2.02 (last year) New Times to come.
New times: 13.732 @ 99.30 on a 1.878 60'
&lt;A HREF="http://y42.photos.yahoo.com/bc/diablo_49418/lst?.dir=/Diablo%27s+photo+album&.src=ph&.order=&.view=t
" TARGET=_blank&gt;Pics of the Iroc&lt;/A&gt;
[This message has been edited by RedIrocZ-28 (edited August 15, 2002).]
Potent77
Mar 16, 2022 12:13 AM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
