Shift points, mainly my 2,500 1-2 shift
Old Aug 14, 2003 | 12:20 AM
oil pan 4's Avatar
My TH700R4 only has around 10,000 miles on it and it shifts at W.O.T. from 1st to 2nd right about 2,500rpms. It shifts as hard as it can but at 2,500rpm it's kinda weak.
How can I fix that?
The 2-3 is only about 3,200 it will have to change to when I get my new engine.
the car is #2 in the sig down there.
Old Aug 14, 2003 | 01:03 AM
stevem's Avatar
is the tv cable adjusted properly
Old Aug 14, 2003 | 10:04 AM
82355's Avatar
Do you understand what your TV cable is and how to adjust it? I am 99% sure that is your problem.
Martin
Old Aug 14, 2003 | 10:34 AM
Geezer powered's Avatar
That sounds more like a valve body promblem than a tv cable.He is have the promblem at wot not normal driving.Has it always done this since the rebuilt.I'd take your car back to the trans place before you mess with with the tv cable.If they see you were mess with it they may void your warrenty.
97TA-WS6-Con
Feb 1, 2015 01:14 PM
number77
Sep 6, 2002 01:29 PM
96z
Sep 5, 2002 07:53 PM
RichardZ SS
Aug 3, 2002 12:26 PM
