tranny leak..
Old Jun 28, 2002 | 10:33 PM
PonyEtrZ28's Avatar
Post tranny leak..
alright, i finally get me car going.. and now i have a bad tranny leak. well i took a shot and replaced the tranny pan gasket., well that was a no go. still leaking good!.
and its not leaking from the lines into the tranny itself.. but somewheres its leaking.
theres fluid on my y-pipe,(which burns up and smokes bad). and its on the starter!.. i cant seem to find the leak!. i thought it may be my front seal. but theres no fluid on the converter. well i donno, if anyone has any ideas as to what i can do to find out what it is. let me know!> thanks
shaun
1987 IROC-Z
355ci, Dart 2.02x1.60, compete forged bottom end, SLP siamesed runners, fully ported Edelbrock manifold and plenum, 58mm TB, Accel 26lb Injectors, Edelbrock headers & y-pipe, Flowmaster 3" cat-back, Rebuilt 700r4, B&M Megashifter, Holley 255lph fuel pump, triple guage pod, !A/C & Heat, !Smog pump, bypassed TB, MJS Ram air, custom PROM, Lakewood control lower control arms, Lakewood adjustable pan hard, Sub-Frames, Hotchkis Strut tower brace, Adjustable Torque Arm, 150hp NOS
IROC Pix
Old Jun 28, 2002 | 11:13 PM
stevem's Avatar
Lightbulb
sounds like your pump seal.mone does it but not to bad unless i leave it in 2nd for a while
Old Jun 29, 2002 | 02:08 PM
PonyEtrZ28's Avatar
where is the pump seal? on the 700r4.
and i only see fluid on passenger side, and on the front of the pan...ill look at that though as soon as i find out what it looks like, and where it is. thanks.
later
shaun
1987 IROC-Z
IROC Pix
Old Jun 29, 2002 | 06:13 PM
PonyEtrZ28's Avatar
well i got the tranny out. and the front seal has no cracks or anything from what i can see.. i looked over the tranny and visually i cant seem to find where it would be coming from!. i guess monday or sometime during the week ill get it over to a shop and have them look at it.
Old Jun 29, 2002 | 08:18 PM
stevem's Avatar
Talking
pump seal is the piece with all the bolt around it (the TC seal is in it)
Old Jun 30, 2002 | 01:52 PM
PonyEtrZ28's Avatar
how much do you guys think it is going to cost me to have a place check it out, and re-gasket the tranny?
thanks guys.
and if it STILL leaks what should i replace next?..
later
shaun
1987 IROC-Z
IROC Pix
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
