52mm Holley TPI TB-noise?
Old Jul 27, 2003 | 09:57 AM
Rosco the Iroc's Avatar
Is anyone else using this TB if so do you get air flow noise?
Old Jul 28, 2003 | 12:15 PM
I guess not.
Old Jul 28, 2003 | 12:21 PM
doug791's Avatar
What type of air flow noise? When i have the air box off and get on the throttle a bit you hear the whistling of the air and its probably louder with an aftermarket tb. Do you hear the air flow noise when its just at idle and the tb should be closed? if not then i doubt theres a problem. Also just check to make sure you have a good seal from your tb to plenum.
Old Jul 28, 2003 | 03:59 PM
It's sounds like a bad vac leak but the lines are hooked up and gsk's line up and everything is tight. I'm also running a Edelbrock runners and intake. Sounds like it's only on the pass side but I can't tell.
Old Jul 28, 2003 | 04:28 PM
doug791's Avatar
if it looks like a duck, walks like a duck, and sounds like a duck chances are its a duck. If there is a sound of a vacuum leak coming from your engine there probably is. Check and double check everything you changed before the problem started.
Old Aug 1, 2003 | 06:32 AM
I used starting fluid to find the leak and 2 injectors are leaking air around the o-rings. now I have to take it apart again!
G-BODYT56
Jan 14, 2022 11:14 PM
95blkss
Sep 22, 2015 03:18 PM
95craz28
11
Sep 12, 2015 07:47 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
