Moser and TA issue has me concerned..
Old Jul 24, 2003 | 11:43 PM
96z's Avatar
96z
I did a search and found quite a few threads in which people had trouble with the TA snapping when having a Moser rear.
Why is it that the bolts dont seem to work? Is there any solution?
I dont need a mangled stock TA if it can be prevented.
I thought I read that many had used the stock TA into the 10's?
Old Jul 25, 2003 | 11:15 PM
Kevin97ss's Avatar
No problem here. Just used red threadlocker and torqued the bolts to 98ft.lbs Then again Im not running tens!
Kevin
Old Jul 26, 2003 | 01:18 AM
ElkyRacer's Avatar
I have noticed that my Spohn tq arm mount for the rear end, is about an 1/8 of an in too tall? When the TA is mounted to the rear end, there is a small gap at the front bolt hole with both bolts tight. Seems as if maybe the TA mount that Moser makes might be too small? Im going to be making some shims for mine to tighten it up.
Kyle
Old Jul 26, 2003 | 08:33 PM
96z's Avatar
96z
Hmmm anyone else have a problem?
Noenav
Mar 1, 2019 07:38 AM
HarleyZ28
Oct 5, 2015 06:23 AM
ddr698
Jan 9, 2015 10:05 AM
Victory Racing
Sep 1, 2002 06:05 PM
