brake problem
Old Jul 20, 2003 | 02:13 PM
shadydavy 95 TA's Avatar
Question brake problem
Creaking noise from left rear brake. A little bit of feedback from the brake pedal too, still firm, not grinding or scrubbing, just kind of a creak. Is this the rear brake pad problem our cars have?
Thanks in advance.
Old Jul 23, 2004 | 12:31 AM
mnky1972's Avatar
Re: brake problem
shadydavy,
Just tonight, i'm pulling up to Wendy's, and all i hear comming to a stop is creeeaaakk. Guess, i have the same problem you do. Even when at a stop, and i pump the brakes, all i hear is creak, creak, creak, creak. Along with you, this creaking noise is comming from the driver rear brake/rotor. Normally i would just deal with the noise, but it is more than noticably loud. I am going to probably take it apart tomorrow, but if anyone out there already knows what it is, it would be greatly appreciated if you would post.
Thanks all
Old Jul 23, 2004 | 01:14 AM
bo3abd's Avatar
Re: brake problem
2 words.
CHEAP PADS.
buy new ones ... buy the most expensive ones .. no more squeeeeeeks!
Old Jul 23, 2004 | 01:21 AM
mnky1972's Avatar
Re: brake problem
Originally Posted by bo3abd
2 words.
CHEAP PADS.
I have very high quality ceramic pads, it's not a squeek, it's a creak, like stepping on old wooden steps.....
Old Jul 25, 2004 | 07:57 AM
slopokrodrigez's Avatar
Re: brake problem
Sounds to me like you have the bad rubber bushing blues. You should swap out the old OEM (read deteriorated) bushings for some polyeurathane jobs. Until that time you can use some spray lube to pinpoint the creak. Spray one at a time and test it until you don't hear the problem anymore.
Magenta_Hearts
Mar 25, 2015 10:24 AM
dluna333
15
Mar 13, 2015 12:30 PM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
