LS1 Wheelie
Old Aug 8, 2002 | 12:39 AM
SmokinGeo's Avatar
Post LS1 Wheelie
About how much crank or wheel horsepower does it take to do a wheelie? I mean the minimum amount in order to do what you'd consider a wheelie. Also, how long can the stock suspension take this for? Is there any way to beef it up to take the abuse?
95 Silver Z28 Camaro
Not bad for 16, eh?
Old Aug 8, 2002 | 02:21 AM
JurisAg02's Avatar
I've seen it be done with 350 rwhp, skinnies and very sticky tires/good track prep...in short HRP
Rick
Old Aug 8, 2002 | 07:10 AM
96fbirdA4's Avatar
I don't know that you could do it on the stock suspension. You would most likely need to purchase a lot of aftermarket equipment to get the car to hook up well enough to pull a wheel.
- Steve - 1998 Pontiac Firebird Trans Am
LS1 A4, 2.73's, Kumho Ecsta Supra 712 245/50/ZR16's, Direct Flow Lid, GMAF, !FRA, Loudmouth, 3" Y-Pipe, AIT Mod, Fan Switch Mod
13.774 @ 103.33, 300rwhp & 308.6rwtq, 97+ RPO Codes, Join The CamaroZ28.Com Users Webring
Old Aug 8, 2002 | 07:25 AM
one wicked element's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 96fbirdA4:
I don't know that you could do it on the stock suspension. You would most likely need to purchase a lot of aftermarket equipment to get the car to hook up well enough to pull a wheel.</font>
Exactly! Its not in how much HP you have, its how well your suspension is set up.
Old Aug 8, 2002 | 09:26 AM
Pro Stock John's Avatar
I lifted tires in 2000, with 375rwhp/408tq...
I lift them higher with 450rwhp/500tq.
PICS:
www.ls1tech.com/moderators/psj
1998 Formula | ARE 422ci iron block with Stage II heads | 40 lb Injectors | LS6 Intake | TTS headers | 3" ORP | Mufflex 4" Catback | MSD Wires | Whisper lid | SLP MAF | FLP level IV 4L60E | Yank TPE4400 | Moser 9"/4.10's | RT Torque Arm | HAL Shocks and Springs (front) | V6 Springs (rear), Alston 8 pt Rollcage | Airlift Airbag | Weld Prostars | ASCD Hood | 11.15@120.30mph 1.53 3625 raceweight LS1TECH.COM
Old Aug 8, 2002 | 09:53 AM
Trevor98ramair's Avatar
Cool
The only suspension mods I have done to my car are a set of G2 LCA relocation brackets, an airbag in the right rear spring, and a set of Hal QA1 12-way adjustable Hal struts. My best 60' time is a 1.588, and you can click on my homepage posted in my sig to see the picture. This is with 361 RWHP. I am getting ready to upgrade with the G2 torque arm, lightweight control arms, and lightweight panhard rod. Another cam swap is in order, too.
Trevor - LGM
'02 SS: 11.63 @ 114.06 MPH, 1.588 60'; 3,515# raceweight, 1,102' D.A.
naturally-aspirated with bolt-ons, a cam, and a fat converter!
L.G. Motorsports (972) 272-7753
Check out the SS!
Old Aug 8, 2002 | 12:57 PM
TireSmoke's Avatar
Can you do this with a stock rear end? Can the stock rear end handle many of these launches?
Steve
2002 Trans Am WS-6
M6, Pewter
Old Aug 8, 2002 | 09:24 PM
Capn Pete's Avatar
Thumbs down
<font face="Verdana, Arial" size="2">Originally posted by TireSmoke:
Can you do this with a stock rear end? Can the stock rear end handle many of these launches?</font>
I'd say "yes" and "no". If you had everything just right (power, traction) your rear end will hold to do this a couple times, but don't expect to go out and behave like a bike and pull "wheelies" at every stop light --- something in your rear end will break (unless something before the rear end breaks - ie: transmission or driveshaft).
To go out and start pulling wheelies, you'd need a lot of beefed up parts on your car, otherwise you're gonna start breaking $h!t left, right, and center. JMO.
2002 Z28 - A4, 2.73's, Blk/blk, leather, T-tops, sport appearance package - just bought on June 26, 2002! - Pics
1981 Z28 - 383, TH350 trans., 3.42 posi - sold August, 2000 - Pics
1973 Camaro - Dad's & my project in the works - to be built: 355 Chevy, 11.5:1 pop-ups, "camel hump" heads (w/2.02 valves), solid cam, 4-speed.....it should be quick! - Pics
Old Aug 10, 2002 | 04:51 PM
cOle96tA's Avatar
Smile
All you have to do is put hydraulics on the front and right when you take off, it will lift the front. Then you get your wheelie.
He He. Im just messin.
Old Aug 11, 2002 | 01:31 PM
ru2slo_99's Avatar
My 95 firebird would lift the front tires about 3" with totally stock suspension and 28x10.5W et streets. The guy I bought my car from did not believe in after market suspension.
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
1slow93z28
Sep 1, 2015 06:22 PM
