HELP......PCM not responding
Old Jul 17, 2003 | 12:10 AM
jdvm95Z28's Avatar
I'm loading a program from PCM4less on my 95 Z and I'm getting an error when I run flshread.......it says ERROR.....no response from PCM.............HUH........I'm no genius so any help would be appreciated......
Old Jul 17, 2003 | 12:54 AM
madwolf's Avatar
Did you already program it and this happened after programming or you did this before programming?
Old Jul 17, 2003 | 09:46 AM
jdvm95Z28's Avatar
It happened as soon as I tried to run flashread..........When I ran flash read to store the PCM original settings it said ERROR: NO REPSONSE FROM PCM....
Old Jul 17, 2003 | 12:25 PM
jdvm95Z28's Avatar
OK I think I've found the problem.............I'm using windows ME and opening the MSDOS "shell window".......I have been told that you can't do it this way.....but I don't know how to do it any other way.....I think you have to go to a web site and download another "True MS-DOS" version......does this sound right?
Old Jul 17, 2003 | 01:08 PM
LWillmann's Avatar
Try doing a command prompt only boot... When you turn on the computer, hold the F8 key down before the Windows logo shows up. You should get a menu. On the menu select Command Prompt Only and press enter.
This should get you to a command prompt, now navigate to and run your flashread program.
Try creating a boot disk in Windows.
Click on start
Click on settings
click on control panel
double-click on add/remove programs
In the add/remove programs window, you should see a tab that reads Windows Setup. Click that.
Click on create startup disk
Follow instructions.
When you're done, make a note of the folder that the flash programming stuff for the car is in.
Close all windows and shut down the computer.
Put your boot disk in drive a: and boot up the computer to a command prompt.
Now you're in true DOS.
do a "CD c:\whaterfolderyouwrotedown" to get to where you saved the program for the PCM.
run your software.
If you can't make a boot disk, borrow one from a buddy.
steelerfan
Jul 2, 2015 09:54 PM
Jul 2, 2015 11:39 AM
DarkKnight
Buyer/Seller Feedback
May 11, 2015 10:03 PM
cobrakilling101
14
Mar 17, 2015 10:42 AM
94Form
Feb 10, 2015 11:23 PM
