nitrous on a stock LT1
Old Jul 9, 2003 | 09:38 PM
ddlouhy127's Avatar
can you spray nitrous on a stock LT1 with 100,000 miles? if so which one is better WET or DRY.
Old Jul 9, 2003 | 10:07 PM
Wild1's Avatar
You are going to get a million answers...
DRY works with your stock injectors and is smog legal in most cases. Keep in mind that if your injectors are prone to locking up, you may want to invest in some good injectors.
WET is relatively easy to tune and you will get a guaranteed mixture. Unfortunately, with excessive fuel you are more prone to flooding which can create an N2O intake backfire.
Yes, you can run it on your car but I wouldn't recommend over 100 HP on your hypereutechtic pistons with your mileage.
D1SC383LT4
Jan 1, 2016 01:56 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
