Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Jet-Hot long tube troubles
Old Jul 9, 2003 | 01:40 PM
Timberwolf's Avatar
I can't get an answer to my questions after emailing chris, so I thought I should point something out to those buying jet-hot long tubes.
http://www.sixtyninecamaro.com/images/jethot.jpg
Notice how far below the top of the header tube the square is... that's when resting against the A4 cross member.
I already purchased 3" exhaust tubing, 3" mufflers, etc. And now none of it will work.
Old Jul 9, 2003 | 02:03 PM
predator's Avatar
looks like you might need to do some bending get a torch and manipulate the tranny mount
Old Jul 9, 2003 | 02:29 PM
Timberwolf's Avatar
Not gonna happen. I ppaid $500 for a set of headers. They should fit the car. I shouldn't have to make the car fit the headers.
Old Jul 9, 2003 | 02:33 PM
JasonD's Avatar
Admin Emeritus
Chris at Jet-Hot didn't reply to you at ALL? That is pretty uncommon, he is usually very good about things like that.
Old Jul 9, 2003 | 03:03 PM
Timberwolf's Avatar
he has since replied, and we are working on a solution. I think the design needs to be changed in all honestly. It's nice that they hug the body for more ground clearance, but when it dumps right inline with the trans cross member and is about 3/4" too high to run a pipe from...the ground clearance, to me, becomes a non-issue.
Old Jul 9, 2003 | 03:06 PM
predator's Avatar
what about getting an aftermarket tranny crossmember i think those have a smaller flange and no lip maybe that would give the clearance
Old Jul 9, 2003 | 03:38 PM
Timberwolf's Avatar
still got hte bolt heads to contend with...and like I said, solving an install issue with a ready-for-market product should not include the words: big hammer, torch, bend, or the phrase "why not go buy..." unless these "adjustments" are spelled out to potential purchasers
Old Jul 9, 2003 | 03:43 PM
predator's Avatar
trust me i feel ya bro but, the damn things are already on i think i would try to make them work somehow even if i had to spend a few more bucs mine will be here in a few days i hope i dont have these probs but i got a lift and a torch so iwill definatley be doing some fab work
Old Jul 9, 2003 | 03:45 PM
predator's Avatar
if it was me i would just grind that lip off the cm i think that would clear enough space for them and i dont thin it will hurt the structural integrity of the cm
Old Jul 9, 2003 | 03:48 PM
blown383's Avatar
Thats pretty common for the Jet Hots....take a look at my pics. The problem is even worse when you have a Global West Track Link installed...the muffler guy had to make a mendral bend so that the piping would turn away from the tranny crossmember and clear the track link. I went with 2.5 inch tubing.
http://community.webshots.com/photo/...70033989wadgTz
http://community.webshots.com/photo/...70034265gvUfWP
-B
Old Jul 9, 2003 | 05:04 PM
rpm4lalo's Avatar
Actually, that won't be enough space.
I have dual 3" piping as well, with a cutout bolted to each header and an H-pipe. My mechanic grinded the cross member, but it still wasn't clearenced enough.
So he modified the flange on the driver's side cutout and got it to work. Took him awhile with the welder and torch but he did flawless work.
It is really tight in there. I wrapped the brake and fuel lines there with some heat shielding for protection.
Old Jul 9, 2003 | 05:15 PM
av8er's Avatar
I had the same problem with my install. It was a torch, grind and modify as needed sort of install. The price and quality of these headers are worth the fit issues. It's not perfect but it is workable and worth it in the long run. Grind or torch all you can off the trans cross-member then drive the car with open headers to an exhaust shop. A decent exhaust shop should be able to custom make or modify a y-pipe as needed to work things out.
JeffA
Old Jul 9, 2003 | 05:20 PM
predator's Avatar
i am going to run an x-pipe wth mine and dual mufflers
Old Jul 10, 2003 | 07:34 AM
bowtiepwr's Avatar
>This should be interesting since mine are still sitting in my garage .
Old Jul 10, 2003 | 02:00 PM
RealQuick's Avatar
I am gonna try the y-pipe Saturday
