ZZ4/ZZ3 cam W/ 95 Opti Possible?
Old Jun 24, 2003 | 11:13 AM
Alvin@pcmforless.com's Avatar
Can anyone answer this question for me?
Can you swap the dowel pin out of a ZZ4 cam to work in a 95 optispark setup? If so how do you swap the pin exactly?
Old Jun 24, 2003 | 11:19 AM
SStrokerAce's Avatar
Slide Hammer.
You might have to change the front of the cam to get the opti drive to work with it too. Only a machine shop with a lathe could do that.
Bret
Old Jun 24, 2003 | 01:08 PM
WS6T3RROR's Avatar
heres some info on how an lt1 cam differs from a standard roller. http://www.compcams.com/catalog/042.html
basicly i think you have to have the pilot hole cut deeper and the end of the cam turned down a little.
i looked into using this cam awhile back from what i can tell it'll make stupid tq and should actually be slightly better than the 210/224 from crane. good luck whatever you decide.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
nikolt1
Feb 27, 2015 09:10 PM
Injuneer
Dec 15, 2014 09:36 AM
