Best wheel cleaners
Old Aug 16, 2002 | 01:42 AM
jasycZ28's Avatar
Post Best wheel cleaners
I can't get the brake dust off my wheels. Are they stained? Help me.
93 Z28 M6 Purple pearl
Borla catback
High flow cat
K&N FIPK
Pro 5.0
Air Foil
Hypertech chip
TB bypass
Mac headers need to be installed
Old Aug 16, 2002 | 11:58 AM
CeeBee94Z's Avatar
Eagle One A2Z its called...works AMAZING.
Its like 4 bucks per container, but I have had nothing that works better. Go to auto zone pick it up and give it a try, you will NOT be disappointed...even if your rims look black there is no scrubbing involved.
If they are real bad just spray some on, take a rag and rub it in a little...hose that off...then spray on one more time and let it sit for like 30 seconds and then hose off one final time. It works wonders and the good thing is that it works on any typr of wheel.
1994 Teal Z28
Cowl Induction Hood
Hurst Short Throw
Edelbrock Headers
Adjustable Borla Cat-Back
SLP CAI
17" Eagle wheels w/245 45 17 Kuhmo Supras
TB Bypass
Air Foil
160 degree thermostat
1LE High flow bellows
13.75@102.13mph
AIM name: kristof30
My 94Z
Old Aug 16, 2002 | 12:09 PM
Brent94Z's Avatar
Super Moderator
Cool
I'll move this to the Show and Shine section. Even though this is called the Appearance section, it is for appearance modifications
Brent Franker * Main Page
94 Vortech Z28 * 96 Z28 SS #1655 & #259
4th Gen Appearance Modification Guide
F-Body Install & Fix-It Guides
Old Aug 16, 2002 | 12:17 PM
moparman's Avatar
Sometimes a clay bar will clean wheels.
Old Aug 16, 2002 | 03:39 PM
97BlackT\A's Avatar
Brake dust by it's nature can get a real grip on your wheels. Most likely it will come off. It is very important to keep coated or painted wheels as clean as possible because brake dust can mess them up if left for long periods.
Once you get them clean, try to wash them thoroughly as often as possible. Avoid using the wheel cleaners on a regular basis because they more often than not contain acids which can eventually damage the finish on your wheels. Rinse thoroughly!
When my wheels are bad, I use diluted Simple Green and my small pressure washer to get the majority off. Spray and blast. Even a hose end sprayer will get most of it off after the SG has been on there a few seconds. The Simple Green cuts it very fast.
Then I wash them with a mitt and two capfuls of carwash soap to a gallon of water. Rinse well.
I'm sure there are better methods, but this works for me.
Jeff
Old Aug 16, 2002 | 04:01 PM
MikeLS's Avatar
Lightbulb
Yes, Jeff, has a good point. Keep in mind that if the wheel cleaner is so strong that you spray it on, hose it off, it's probably strong enough to cloud or etch your wheels too. Most of these types of solutions are based on acid. The acid is what eats away the brake dust and dirt. The stronger the acid, the easier it cleans the wheel, and the easier it is to cloud or dull the finish on the wheel over time. You don't want to use these strong cleaners very often at all. I recommend that once you have them cleaned, clean them with a milder solution like Simple Green or even your car wash soap during every car wash. Otherwise you may notice your nice wheels taking on a duller or cloudier appearance after a while.
*My 1992 Camaro RS 25th Anniv.*
Flowmaster Crossflow, K&N, 20% 3M Panther Black Tint
JL Audio 3 10", PPI PC2100, other Kenwood & Pioneer goodies...
Show Car Shine by ZainoBros! - Thanks Sal!
NewsBot
Jun 24, 2015 07:50 AM
jasonduaine
Jun 4, 2015 09:29 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Fatdog2
Feb 13, 2015 08:19 PM
Collector Car
Jan 5, 2015 10:58 AM
