Times with JetHot Lt's and duals
Old Jun 15, 2003 | 07:10 PM
Drew778/94Z's Avatar
I was also playing with an low bottle w/ the 100 jets
1.809 7.992 87.18 12.516 109.26
2.053 8.328 86.67 12.866 108.69
1.997 7.876 94.15 12.039 119.01 n2o
1.862 8.011 86.88 12.52 109.52
2.063 8.032 89.61 12.457 111.11 n2o
1.866 7.996 87.91 12.507 109.47
2.087 8.347 86.89 12.865 109.26
2.077 7.895 92.58 12.339 112.87 n2o
1.879 8.01 87.37 12.514 109.46
I thought after the the LT's I'd be closer to 110 mph
I still have my ASP pully to put on, hope it helps some
Old Jun 15, 2003 | 11:45 PM
AL SS590 M6's Avatar
Question Re: Times with JetHot Lt's and duals
What were the weather conditions like compared to your previous best? May you can run 110s in better air.
Old Jun 16, 2003 | 12:36 AM
I thought it was a pretty good night?
I'll try again next week, my best before was 108.74
I hope the LT's and dual's would give me more than 10 hp
Old Jun 16, 2003 | 04:41 AM
I track weather on every run. Just because it feels kind of nice out doesn't mean that the air is good for making horsepower
Take note of barometric pressure, temperature, and humidity. I bought an old indoor wall hanging weather station at a yard sale for $5 to take to the track with me. And use only it to compare one run to the next. After a short while you can start drawing a corrilation between the weather and your MPH and ET (if traction is the same).
I would sure think that LTs and duals would get you 20-30 HP. Maybe you need some tuning?
Old Jun 16, 2003 | 05:15 AM
2002Z28SSConv's Avatar
My stock Predator tune left a lot on the table. I only gaine 5 hp and 5 Tq. The A/F readings on the dyno showed it was running way rich once we installed the tuning. It's lots better now with it running leaner. I didn't get additional pulls but at least there is a noticable change now. Plus you've added the exaust mods into the equation. Your best bet will probably be tuning, just to get the A/F and timing set at peak power settings. I know it's a pis$er that you spent $$$ on the programmer but look at it this way. You didn't buy the 'performance tune'. You bought the tool that allows you to adjust your tuning pretty easily.
Old Jun 16, 2003 | 10:20 AM
Thanks guys, I try leaning it out a little, maybe that will help.
Old Jun 17, 2003 | 01:46 AM
I also forgot the wolf roll-bar is an extra 60-70 lbs
I'll taking out the rear seat belts to help a little.
Old Jun 26, 2003 | 02:39 AM
With the carpet removed and I leaned out a little at WOT.
2.078 8.500 86.92 13.056 108.73
1.967 8.305 87.09 12.838 109.26
1.85 7.976 88.04 12.474 110.00
1.821 7.935 87.91 12.431 110.01
1.929 8.261 86.92 12.791 109.14
1.841 7.966 88.26 12.463 110.08
Finally hit 110
Old Jun 26, 2003 | 07:27 AM
chpmnsws6's Avatar
SWEEEEEEEEEEEET!!!!!!!! good job man, now i wish i could follow suit
Old Jun 27, 2003 | 08:40 PM
Thanks, but I still want more
My goal is 11's with bolt-on's
nikolt1
Feb 27, 2015 09:10 PM
Jan 23, 2015 01:13 PM
alphaauto
Jan 22, 2015 08:02 PM
4586
Dec 31, 2014 02:21 PM
