Z6 Leaves Streaks Sometimes..
Old Jun 2, 2002 | 04:43 PM
Espo's Avatar
Post Z6 Leaves Streaks Sometimes..
For some reason Z6 is starting to leave streaks when I clean my hood???
If I spray the hood and wipe it down about 1min later I have to rub my piant hardcore with a towel to get rid of them. Today I made a huge scratch on my hood because of it!! I guess there was some dirt on my towel..
But why is it doing that???
Also I can apply Z6 in the sun right, my hood was pretty hot when I was doing it..
Old Jun 2, 2002 | 06:23 PM
Kevin V 2002 SS's Avatar
It is best to use the Z-6 on a cool surface. When you spray a small area with the Z-6, don't wait to buff it off, do it immediately. It can dry so quickly on a hot surface it can streak. You can also apply the Z-6 to the towel instead of the surface and it will be easier to use and only use a small amount.
Louisville, KY
[This message has been edited by Kevin V 2002 SS (edited June 02, 2002).]
Old Jun 2, 2002 | 06:51 PM
KevinSS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Espo:
</font>
You did several things wrong, as Kevin V said you immediately buff the Z-6 off when you mist it on your paint, there is no waiting, it even says on the back of the Z-6 bottle not to let the Z-6 dry on the paint. Also, you never, ever want to spray the entire hood or large surface at one time, your work area for Z-6ing should only be about 1 square foot.
Also, if you as Kevin V said spray Z-6 onto a hot surface it starts to evaporate too quickly, you see, Z-6 is heat activated, this is why it disappears when you start running the towel over the paint.
96 Black Impala SS
www.zainobros.com
Remember #3
Old Jun 3, 2002 | 10:46 PM
JSK333's Avatar
I've also found that it'll streak if there is too much dirt/dust on the paint. Make sure the car doesn't actually need washed.
Solomon
What's life all about?
Silver '95 Camaro Z28 M6: 14.3 @ 98.7 - With problems, but will improve!
White '90 Cadillac deVille: 16.3 @ 81.4 - Not likely to change soon.
Learn the basics of tuning your OBDI LT1 PCM!
WobblySausage
Oct 7, 2015 10:09 AM
98-LS1Z28
Sep 8, 2015 03:12 PM
Bails098
Aug 17, 2015 05:15 PM
Aug 17, 2015 09:50 AM
Aug 7, 2015 08:52 AM
