TH350 kickdown cable in a 4th gen
Old Jun 12, 2003 | 08:10 PM
ChrisPolser's Avatar
I got my th350 installed in my 94, and the only thing I lack is a kickdown cable that will reach the throttle body. I am many inches short of a connection there. Is there an off the shelf cable that I can use for this application? Thanks, Chris.
Old Jun 13, 2003 | 08:02 AM
Shon Herron's Avatar
I do not run one and drive it everyday.
The shop that did my tranny said there was not a GOOD one out there, they are all about the same....if what you have is too short, wonder if Lokar would custom make one? I have not checked so i have no clue....
Old Jun 13, 2003 | 08:33 AM
cable
Do you use a fully manual valve body? In that case you wouldn't need one anyway I guess. I was given a website, www.hotrodlane.cc that would have something, but I can't find it on their site - although they have some other nice parts. Otherwise, I assume that you have one (or part of one) to fill the hole in the tranny?
If all else fails I may try to extend the slim little bracket that hooks to the TB.
Old Jun 13, 2003 | 08:42 AM
I run a regular VB.
The shop had what looked like a 'stock' end cut and sealed up to put in the kickdown hole of the trans.
Good luck!
james4154
Jun 15, 2015 12:16 PM
dylan1303
May 22, 2015 12:24 PM
kolbaso
May 21, 2015 01:49 PM
