Front end rebuild
Old Jun 4, 2003 | 02:47 AM
pacesetter's Avatar
Front end rebuild
I am looking at this front end kit
http://www.p-s-t.com/gm/gmfekpgs.html#CHEVROLET
2 Upper Ball Joints
2 Lower Ball Joints
4 POLYGRAPHITEŽ Upper Inner Control Arm Bushings
2 or 4 POLYGRAPHITEŽ Lower Inner Control Arm Bushings
2 POLYGRAPHITEŽ Strut Rod Bushings (if required)
2 Outer Tie Rod Ends
2 POLYGRAPHITEŽ Stabilizer Links
2 POLYGRAPHITEŽ Sway Bar Bushings with Brackets
Control Arm Bumpers (for most models)
2 Inner Tie Rod Ends
Tie Rod Adjusting Sleeves
1 Idler Arm
2 Upper Inner Shafts
Plus all their parts have a 20 year warranty!
Its $359 for the whole thing, I would do this myself, but I have never done some of it before, like the ball joints... I dont want to dive in over my head, so I am going to take it to a shop to have them installed. Anything else I should have done while I am re-building this? I am replacing the front shocks/springs as well. THX
Old Jun 4, 2003 | 12:21 PM
angel71rs's Avatar
Couple of things to consider: when my nephew was going to do the front end of his Z28, he condsidered a kit from pst, then got pricing from Autozone on individual pieces and it ended up cheaper with the Zone. Maybe it was because he didn't buy stuff like the tie rod adjusting sleeves and the upper shafts which usually are still in good shape and reusable (as his were) and because he went with stock replacements, not poly.
Which brings me to: he chose stock replacements cause a friend of his had a pst kit installed and it ended up being a tooth rattler is was so harsh. He just wanted his front end to lose the mushiness, he wasn't after a high performance road carver. If you don't mind the stiffness from solid hard plastic bushings, this shouldn't be a problem for you.
Old Jun 5, 2003 | 12:23 AM
CoryM's Avatar
Only thing left is the centre link and steering box. Make sure there is no slop there. Also you may need some new bumpstops and spring isolators? I often dont use the isolators though.
Good Luck.
CoryM
Old Jun 6, 2003 | 01:45 PM
Z28SORR's Avatar
Just did this to my 85 ElCamino. IMO it's not harsh at all. The bump stop were in the kit?
This would also be the perfect time to upgrade the sway bars.
8T8IROC
Mar 26, 2015 09:02 PM
karguy16
Mar 6, 2015 01:33 AM
grabbem88
Feb 23, 2015 09:41 PM
siguy
Nov 27, 2014 10:07 AM
