Subwoofer Voice Coils
Old May 30, 2003 | 06:59 AM
Grover's Avatar
What is the benefit of using a dual voice coil sub vs. a single voice coil sub? I understand quite a bit about car audio, but never really got a good explanation on the subs voice coils.
Thanks.
Old May 30, 2003 | 08:01 AM
rthompson's Avatar
the benefit is different wiring configurations.
A dual 4 ohm woofer is able to be easily wired to 2 or 8 ohm or you can use one coil for a 4 ohm load.
If you want to use one coil it also has some benefits. You can adjust the qts of the subwoofer by using one as an eletromagnetic brake by keeping the coil open, short or using a resistor. The benefit is that you can tweak it to work better in a wider variety of boxes, but the drawback is that you lose 3 DB of efficiency and putting power to one coil the thermal power handling is about 2/3 what using both coils would be.
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Z Power
Sep 19, 2015 11:19 PM
rvonsternberg
Sep 14, 2015 11:58 AM
