TPI conversation to an LT1
Old May 28, 2003 | 11:05 AM
Need4SpeedB4C's Avatar
Hey anyone here swapped out an 96-97 LT1 intake, computer wireing harness, injectors..etc and put it on their 3rd gen engine?
-Mace
Old May 28, 2003 | 01:13 PM
Screamin95's Avatar
you dont need the comp, wire harness, just the intake. check out
www.lt1intake.com
Old May 28, 2003 | 08:55 PM
Well, I was referring to take the intake. I know about that, even though I still haven't seen any dyno results or any other stories about it.
I'm talking about everything though. Doesn't the L98 fire differantly than the Lt1? I just figured if I got the computer, wireing harness, fuel rail, injectors, and the intake from a 96-97 Camaro I could bolt everything on my L98, drop the TPI and I could also use the OBDII.
-Mace
Old May 28, 2003 | 09:02 PM
man...I just made myself look retarded...I said "TPI CONVERSATION" hehe...wooo...long day...Obviously, I meant conversion .
-Mace
Old May 29, 2003 | 02:33 AM
Zepher's Avatar
The hardest part would be figuring out how to convert the Dist signal into an opti signal for the PCM.
I am not sure if you can run an Opti on a regular sbc and run an sbc waterpump and I am not sure if an LT1 waterpump with an electric pump will bolt to a regular sbc.
I could have tried this at one time when I had a couple of 305's and LT1's in my garage, but now all I have are LT1 parts.
Dec 31, 2014 02:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
4586
Dec 6, 2014 05:20 PM
