basic 3rd gen advice
Old May 26, 2003 | 01:38 PM
mikeV8's Avatar
Im looking forward to gettting a Iroc camaro and i don't know much about them yet. What are the basic power mods for a 3rd gen. I plan on getting an Iroc so can anyone give me some more general info on this car. But if there are any better years for your money (i dont have much) please let me know.
Old May 26, 2003 | 04:02 PM
DarthIROC's Avatar
The newer the better. If you can get a 91-92 they run a little harder and have different GFX, so they look a little meaner too. But they didnt make IROCs those years just Z28s (as if it makes a difference). You will want to get a TPI model. If you can get a 350. In my opinion if you get a TPI 350 car, then add a stall convertor, stealth-ram, and exhaust you will give any LT1 a very hard time
Old May 26, 2003 | 04:30 PM
doug791's Avatar
i find the 89 to be the golden year. its the newest year that has the stronger 9 bolt rear.
Old May 26, 2003 | 05:09 PM
fyrhwk1's Avatar
Subframe connectors, every 3rd gen whether its a daily driver or a hardcore racer needs them, tightens up the whole feel of the car and gets rid of a bunch of possible rattles. After that a wonderbar (steering box brace) and LCAs will help you put the power down, even a stock 350 can flex the stock ****ty stamped pieces let alone an upgraded motor with a high stall converter. Do you want a manual or auto? if manual dont bother with building a T-5, you can get a T-56 crossmember shipped to you for under $200, the rest can be gotten from a junkyard, plus it'll hold all the power you want it to unless you're gettting crazy with it.
Old May 26, 2003 | 08:42 PM
Rice Killer87's Avatar
1 of the best power adders for a 3rd gen is headers...about 15-20 HP over the stock exhaust manifolds.
Old May 26, 2003 | 09:12 PM
Tbird232ci's Avatar
did they come with rear disks too?
Old May 27, 2003 | 09:06 AM
BigCasino87GTA's Avatar
From: Chillin' with Frank, Dino, Sammy and Pete at the Sands!
"did they come with rear disks too?"
yes
Old May 27, 2003 | 10:08 AM
atlasengr's Avatar
Make it a 350!
Do not get a 305. Make sure whatever year you go with, get a 350 in it. That would make your options 87 or newer. Look for rear disk brakes, L98 on the option codes and and "8" on the vin not an "F", I think it's the 8th digit on the Vin. Also, the 5.7L markon the hood next to the hood hinge, not 5.0L. That's all, good luck getting one and if you want to make it scream off the bat, 100 shot will do just that!--No bull
Old May 27, 2003 | 10:25 AM
IROC350's Avatar
they did not make irocs in 91-92. they came with 4 wheel discs and the 9 bolt rear. try to find one with a 3.45 gear or so, they are expensive!! headers will probably be your best mod for cheap. with all 3rd gen V8's, they tend to open 'em up a lot! the 350's did not come with standard tranny's so try and find one with a good 700R4 transmission. the t-tops will leak if you get one with t-tops, but those are always good to have SFC's are a must also!
Old May 27, 2003 | 12:35 PM
StealthElephant's Avatar
don't you have to pull the motor to install headers?
Old May 27, 2003 | 02:02 PM
87DJP2001's Avatar
No, you Do Not have to pull the motor to install headers. Some brands are more of a bitch then others to install.
Old May 27, 2003 | 07:02 PM
lordmetalz28's Avatar
personally i got a 305 and it moves like a ****. defintley go with an exhaust a flowmaster is a great choice dynomax sucks and is very restrictive. some freebies to up your hp a bit but not major would be some k and n drop ins removing your baffles from your air box and also try by passing your tb coolant and getting some ac rapid fire plugs your car will move after this
Old May 27, 2003 | 09:06 PM
TheGreatJ's Avatar
With the Hedman shorties I just put in, I had to jack the driver's side of the motor up an inch and a half, but once I did that they just dropped right in. I also noticed a SUBSTANTIAL power gain on my moderately-built 355 over stock L98 manifolds.
Get a 350TPI car, put headers, exhaust, and SFC's under it, then get into heavier mods (gears, convertor, intake tract etc.)
Old May 27, 2003 | 09:21 PM
Dirt Reynolds's Avatar
Bingo.
1989 was the only year you could get the PBR single-piston caliper rear discs with the 9-bolt diff. It was also the last year for the 9-bolt, which is much stronger than the 10-bolt. The 9-bolt has a 7.75" ring gear vs. the 7.625" of the 90-92 cars and 4th gen cars. Earlier 3rd gen f-bods got a 7.5" ring gear 10 bolt. The other advantage of the Borg Warner 9-bolt is the fact they do not have c-clips.
J65 4-wheel discs were available in 90-92 but were the Delco Morraine calipers, not the huge PBR units.
1988-89 L98 TPI 350, and the TPI 305 (manual transmission only version) also got the biggest roller cams of the 3rd gen era; 207/213 @ .050". They are also MAF cars, so they respond to mods without custom prom burning (to a point at least.)
Look in the glove box for the option codes sticker. JG1 is the aluminum driveshaft option with you could also get in 1989 (mine has this option.)
Also in beginning in 1989 you could opt for option N10 - dual catalytic converters, which added another 10HP to the 305 TPI (manaul trans. version only) and the big-gun L98 350.
The GTA is the most expensive of the 3rd gen lineup. They came standard with a whole slew of goodies like WS6 suspension and a TPI engine. Be advised the 305 TPI engines with auto. transmissions have the smallest cam profiles (aka the dreaded 'peanut' cam) and consequently, the lowest power outputs of the Tuned Port engines.
Find an L98 car (350 TPI). They have a tremendous amount of torque, and are worth the search. I found a 1989 GTA Gunmetal Metallic on a corner car lot last year. I wasn't even looking for another car, but after checking out the option codes and seeing the car had all the good stuff (PBR brakes, alum. driveshaft, dual cats, L98, etc) I decided it might be a good idea to pick it up. I havent regretted it one iota. Great car, super seats (the GTA has incredible seats), steering wheel stereo controls, and after checking out online sources, I found out only 644 GTA's were made in 1989 in Gunmetal Metallic.
Bottom line is these are great cars for the bucks. They are also getting scarcer by the day. Good luck with the search.
Old May 27, 2003 | 09:53 PM
doug791's Avatar
plus in 90 they started putting in air bags which is a great safety feature but sucks if you want to change the steering wheel. Massive fines if a copper notices
